Current Drawn
linguist
I am trying to calculate the current drawn by an inductive circuit from the total Power, Voltage & Power Factor.
If I have a an inductive circuit with a load of 10kW as an example & the circuit has a power factor of 0.4, the voltage is 100v 50Hz.
I know from Ohms law that you have I = P/V so 10,000/100 =100A
But the power factor is 0.4 making the circuit draw more current so how do I factor this in?.
Cheers
I'm not sure if this is correct, could you have a look & see for me please.
Power in an AC circuit is Volts X Amps X Power Factor.
Power is Constant at 10kW in this case so 100V X 250A X .4pf = 10,000W--10kW.
Do I have this correct?
Cheers
Hello,
Since
P=E*I*pf
then
I=P/(E*pf)
