    Dismiss Notice
Current Circuits, DVM meter will short out when measuring on current circuits
Discussion in 'General Electronics Chat' started by Billy Mayo, Dec 17, 2013.
Thread Status:
  1. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,435
    933
    Canada, of course!
    Both inputs of U7 are connected together making it a simple Cmos inverter, not a NAND gate.
    Don't guess wrongly about the 4043, look it up.
  2. Billy Mayo
    Billy Mayo Member
    Mar 24, 2013
    825
    2
  3. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,907
    1,094
    I think CR11 should act as a -0.6 V clamp which I don't think it is doing.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. audioguru
    Mar 16, 2004
    32,435
    933
    Canada, of course!
    Their truth tables are so simple that I am surprised that you do not know. Maybe you do not know English well? Or means or. AND means and.
    To make a NOR gate. U7A has both inputs connected together making an inverter, not a NAND gate.
    You are missing an education in the basics of electronics.
    When the anode of either or both diodes is/are positive then it/they conduct and raise the input voltage of U7A.
    When the anode of a diode is low then it does not conduct and does nothing.
    When both anodes of the diodes are low then R110 pulls down the input of U7A to be low.
    The anode is the input. If the anode is high then it conducts and pulls its cathode high. If the anode is low then the cathode and the input of U7A can be made low by R110 or made high by the other diode, then this diode is reverse-biased and does not conduct so it does nothing. It has two diodes making an OR gate. If either (one OR the other) OR both inputs are high then the output is high.
    An AND gate has its output high only when one input AND the other input are both high. Simple English.
    Logic does not "pass through" a diode. Look at the diode to see if it conducts or if it does not conduct.
  6. KeepItSimpleStupid
    Oct 30, 2010
    9,907
    1,094
    Way back when there was a logic family called DTL: See: http://en.wikipedia.org/wiki/Diode–transistor_logic Before that, there was a logic family called RTL or Resistor Transistor Logic.
    The Diode trick appears every once and while and is used as a Wired OR even without a transistor. I used two diodes in the car, to make a buzzer work when only the driver's door was open and the headlights were on.
  7. audioguru
    Mar 16, 2004
    32,435
    933
    Canada, of course!
    I am leaving this silly thread because I am tired of answering millions of questions about simple basic electronics.
  8. Billy Mayo
    Billy Mayo Member
    Mar 24, 2013
    825
    2
    well whats the problem with the board if its so simple? i got my soldering iron fired up ready to go tell me what to change to fix this problem? and what is that buss called? its very basic and simple ?
  9. Billy Mayo
    Billy Mayo Member
    Mar 24, 2013
    825
    2
    the designer had an NAND gate, then he uses it as in inverter , and then uses diodes and a resistor as a nor gate , there is a reason why the designer did this
    why didn't the designer use a nor gate ic chip? why didn't the designer use a inverter ic chip instead of using an NAND gate as an inverter
  10. 4pyros
    4pyros Well-Known Member Most Helpful Member
    Oct 22, 2010
    4,368
    282
    Pennsylvania, USA
    OMG these boards go in planes!!!!!!
    • Like Like x 1
  11. Little Ghostman
    Little Ghostman Well-Known Member Most Helpful Member
    Jan 7, 2011
    3,702
    426
    SCOTLAND
    Are you making a joke? or are you really serious?
    I dont mean to rude at all but, I can see no way that erm, well i just dont see how these are for planes?? I always thought anything to do with flying was strictly controlled? How do you get a job fixing plane stuff with no qualification's? How does a company get a contract to fix plane bit's? with poorly trained staff and sherbert equipment?
    None of this makes any logical sense to me. As for AND, OR,NAND,NOR gates etc and diodes, every book I have, has got these in the first chapter or two, so how can you work with them and not (NOT) know? They even give a small clue in there names!!!
    AND ____ means both or one AND the other one = HIGH
    OR _____ means ONE OR the other ONE means output = HIGH
    See there is a clue, anything with a N in front basically means its back to front.
    But planes, NO i dont believe that for a minuet. Too many would be falling out the sky, Maybe helicopters? we had one hit a pub in Scotland the other week, so helicopters would make sense
  12. Billy Mayo
    Billy Mayo Member
    Mar 24, 2013
    825
    2
    When you clear the RESET on latches , the latches shouldn't keep a voltage it should be at zero volts
    1.) When I switch on the Enable switch to the Latch CD4043 , It will output a +14 volt , why is that , it should be zero volts right?
    2.) There is a CD4017 Decade counter before the Latch CD4043, The CD4017 Decade counter takes 3 seconds to output a pulse to pulse the SET input pin on the Latch CD4043
    Why am I getting an output on the Latch CD4043 in milliseconds Way before the CD4017 Decade counter?
    When I switch on the enable switch back and forth 10 times , I will get 10 output pulses from the Latch CD4043, how can that be? when the CD4017 Decade counter has to take 3 seconds to output a pulse to trigger and pulse the LATCH set input pin?
    Is this Latch CD4043 defective?
    What's the Difference between a Flip Flop VS a Latch?
    The CD4017 is a Decade counter
    The Clock input pin has a 1 hz = 1 second
    So it takes 3 clock pulses to output on Pin#7 of the CD4017
  13. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,886
    500
    Cleveland, OH, USA
    If you look closely at some of the labels, one interpretation could be that the controls mentioned, e.g., flap, pitch gyro, roll, and slat, are aircraft controls. In fact, it may be the autopilot.
    I hope it is not for an airplane "made in China to Boeing specifications."
    John
  14. Little Ghostman
    Jan 7, 2011
    3,702
    426
    SCOTLAND
    So what your saying is, we just have to look for the planes that are lost? :facepalm:
    Maybe it's one of those fakes China make, Didnt know you could buy jets on ebay:stop:
    Enough joking, I honestly find it hard to work all this out, I wont post what confuses me, I dont want to be rude or upset people. This time i will keep my mouth shut, but i wont be moving, and you will never get me on a plane again!:meh:
    So many good people needing jobs:grumpy:.
  15. 4pyros
    Oct 22, 2010
    4,368
    282
    Pennsylvania, USA
    Yes I am afraid to contribute to Billys threads anymore.
    If he really is trying to repair aircraft boards by forcing outputs or replacing every chip than I may never fly again ether!
  16. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,174
    644
    Ex Yorks' Hants UK
    Hi guys,
    Please keep on Topic.:(
    E
  17. JimB
    JimB Super Moderator Most Helpful Member
    Sep 11, 2004
    6,324
    585
    Peterhead, Scotland
    But what is the topic?
    The title of the thread is:
    That is all over the place before we start.
    As the board under "repair" appear to be used in a aircraft, that should raise concerns for any responsible engineer/technician.
  18. ericgibbs
    Jan 4, 2007
    21,174
    644
    Ex Yorks' Hants UK
    hi Jim,
    I agree the topic is somewhat ambiguous , but posts like #213 and #214 have no technical content whatsoever regarding the OPs query.
    With regard to the 'safety' aspects of the OP's work, I would say it his employers who are responsible for ensuring safety standards for their work.
    Eric
  19. Little Ghostman
    Jan 7, 2011
    3,702
    426
    SCOTLAND
    GM11
    " So a plane goes down, and you sleep easy, because it was there duty to ensure safety and not your responsibility to raise concerns? Sorry Eric i am truly shocked, that you hold such views. IF these are for planes, then how responsible is it to continue to answer these posts with technical help? "
    posted by Ghostman11 not LG
  20. ericgibbs
    Jan 4, 2007
    21,174
    644
    Ex Yorks' Hants UK
    I did NOT say it was NOT my responsibility, read my post.!
    Safety of any commercial product is the sole responsibility of the company who provides or monitors the product.
    How is the nonsense in post #213 going to improve the safety aspect of the OP's services.??
    E
  21. JimB
    Sep 11, 2004
    6,324
    585
    Peterhead, Scotland
    Eric, you are quite correct.
    Would the OPs employer be happy to read these discussions here on ETO?
    I wonder.
    What I am about to say could form the basis of a separate thread on the ethics of discussing your employers business on an open forum.
    We do not know which country the OP is from or which company he works for.
    My own personal ethic is that I do not discuss details of my former employers business or my clients business since I have been self employed.
    Obviously over the years I have related various experiences and happenings in order to illustrate points being discussed here on ETO.
    Having said that, unlike the OP, I do not drag out a tail of woe and incompetance which drifts from one OMG WTF to the next one.
    Many people here have tried to give good advice and direction on various aspects of faultfinding in electronic systems, but it all seems to fall on deaf ears.
    Sadly there is nothing positive that I can add to this or any of the other related threads.
Thread Status:
Share This Page
