Sceadwian said:Exactly from what language to what language are you trying to convert?
Nigel Goodwin said:Essentially what you're wanting to do is the same as recreating the egg by starting with an omelette - with the added problem that you don't even know what an egg is supposed to look like!.
4electros said:This is absolutely right
but anyway that was just a thought and i'm convinced now to read it carefullly with ASM to know what it looks like.
Nigel Goodwin said:Unfortunately, if the program was compiled from a high level language (particularly from C), it produces very hard to read assembler!. So it's usually pretty obvious if it was actually written in assembler originally or not.
mramos1 said:Does the program have labels that make since? Readable?
If so it is probably assembler. Can you post a small section of code?
3v0 said:A quick look on the web did not turn one up.
Nigel Goodwin said:Can you name any processor that has a 'de-compiler' available for it?, I've never heard of such a thing? - although it was possible on some PC compilers, with all debugging options turned ON, and all optimisation turned OFF, because it then saved enough of the source code with the EXE file to reconstruct it.
Salamander: a .NET decompiler that converts executable files (.EXE or .DLL) from Intermediate Language (IL, MSIL, CIL) binary format to high-level source codes, such as C#, managed C++, Visual Basic.NET, etc. $1099 per license
Boomerang: A general, open source, retargetable decompiler of machine code programs
DJ Java Decompiler: Windows 95/98/Me/NT/2000/XP decompiler and disassembler for Java that reconstructs the original source code from the compiled binary CLASS files (for example Java applets).
