Common Emitter's voltage gain.
alphacat
I was asked what is the voltage gain of Q17.
(all transistors operate in the forward active region).
My answer is: -gm17 * (ro17 || ro13B).
Am I right please?
Thank you.
I'll explain how I reached it.
av = -Gm * Rout.
Gm = gm17 / (1 + gm17 * RE)
Rout = (ro17 || ro13B) * (1 + gm17 * RE)
Your attachment doesn't work so we don't know what you are talking about.
I don't know what is the output impedance of the current mirror.
You are leaving out the effects of the emitter resistor. The final gain is divided by that resistor.
Edit: I looked again, and you have RE hidden in your gm calculation. That's good. I think you can simplify your result to:
(ro17||ro13B)/RE, ingoring the very small effect of base current.
Thanks for the help. :)
Could you explain please how you reached (ro17||ro13B)/RE?
It is known that av = -Gm * Rout, and according to my calculations:
Use the approximation: 1 + gmRE ~= gmRE;
since gmRE >> 1 typically.
For example, if IC = 100mA and RE = 100 ohms, then gm = 100/25 = 4ma/mv (at room temperature), and gmRE = 400V/V, which is much greater than 1. The approximation works for most reasonable values of IC, but may fail at very low currents.
However, your original calculation was correct. A+
