zevon8 said:Bottom line... you just get good at recognizing them through experience.
duffman said:Yes, I do. It also seems that after I apply solder to the opposite side, It is impossible not to get solder on the tip of the iron. Is that just me? Also is that ok? If I apply a good connection and the solder covers the joint on one side, but I get the tip dirty as well?
Just make sure you're not in it when wiping your soldering iron...Nigel Goodwin said:...or a jeans trouser leg!...
Exo said:Just make sure you're not in it when wiping your soldering iron...Nigel Goodwin said:...or a jeans trouser leg!...
Nigel Goodwin said:I always am! - it works best with jeans as the material is nice and thick!, don't try it with nylon trousers
well I went over and had a looksee at the kit I was working on and it seems as if nearly all the joints I made were cold!!
