Was wondering if someone here may be knowing of an interface chip, which can sit between a microcontroller and a sensor and do the level shifting per the following scenario:
Inputs pulses coming from a sensor (12v), need to be shifted down to 5v level by this chip, before feeding to microcontroller pins.
On the reverse, output from micro must be shifted up to 12v by the interace chip. This digital 12v level must appear on 8 pins on the interface chip, on the return path to the sensor.
(pulses will be 20 microsecond wide.)
Thank you.
Thank you.
