capasitor question ??
indie
just a short question...what will happen if i'm not use 2 capasitor behind the x'tal oscillator ?? :roll:
It might not oscillate - the oscillator circuits are designed with those two capacitors as part of the circuit - it 'may' work just on stray capacitance, but it might not be reliable.
oscillator question ??
than is there any different between analog oscillator with PIC oscillator ??
Re: oscillator question ??
Depends what you mean by an 'analogue oscillator'?, the clock oscillator is basically a squarewave oscillator using logic gates, what I would call an 'analogue oscillator' would usually output a sine wave.
yup..i mean the analogue oscillator that generate sine wave. what is the different between them??
A sine wave oscillator provides just enough positive feedback to oscillate, a square wave one provides a much greater degree of positive feedback.
waw...actually i don't really understand what you mean?? can you explain to me more detail?? :wink:
Positive feedback is what makes an oscillator oscillate, essentially it increases the gain until it oscillates. If you have just enough gain it will gently swing from high to low, giving a sinewave - if you have lots too much gain it will slam from power rail to power rail, giving a squarewave output.
