can not tx out txt mesage...
hhhsssmmm
hello
i can not get the text message receive on my cell phone or any other network via the program coding below.
it simply desinged so that to send sms only .... not receive
i can get all other command resposnes back from the gsm modem and display on my LCD....so i know that the hardware is working correctly and that my below code snippet is wrong somewhere.
plz can someone look at my code below and tell me what is wrong and why i can not receive text mesage on my cell phone.
my setup involves the following...
PIC18F4220 @ 20MHz C18
MAX202CPE
GSM Modem Siemens Model TC35
thank you
haseeb
void main(void)
putUSARTcustom( "AT+CMGF=" ); //write the 'SMS Format Selection' AT command syntax
    TXREG = 1;  //SMS format in TEXT mode
    while(TXSTAbits.TRMT==0); //wait until transmition is complete
    TXREG = 0x0D;  //write CR
    while(1) //loop for 'OK' reply from modem
        while(PIR1bits.RCIF == 0); //wait for data reply from GSM Modem
        GSM_Byte_1 = RCREG; //reading RCREG clears RCIF
        GSM_Byte_2 = RCREG; //reading RCREG clears RCIF
        if(GSM_Byte_1 == 'O' && GSM_Byte_2 == 'K') //break from while loop when u get 'OK'
            break;
    putUSARTcustom( "AT+CMGS=xxxxxxxxxxx" ); //enter in the desired number to send SMS via AT command
    while(1) //loop for '>' reply from modem
        if(GSM_Byte_1 == '>') //break from while loop when u get '>'
            break;
    putUSARTcustom( "PIC" ); //enter desird text to be sent
    TXREG = 0x1B;  //write ESC to finish sending text message
    while(1); //end program
}//end of main()
void putUSARTcustom(const rom char *data)
    char c;
      while ((c = *data++))
           TXREG = c; //Transmit a byte
} //end of putUSARTcustom()
Just looking at your code, why have you seperated your values from the command string?
For example, why not just write:
putUSARTcustom( "AT+CMGF=1\r" ); //write the 'SMS Format Selection' AT command syntax
Just a thought.
Have you put in a check to see if the code section completes?
For example, when you send the first command, have something written to the LCD to say it has completed, and the same with the AT+CMGS command.
I suppose you have tried this with Hyperterminal or TerraTerm to make sure it will actually send correctly?
