    Dismiss Notice
calculator program 8051
Discussion in '8051/8951' started by sirous, Dec 7, 2006.
  1. sirous
    sirous New Member
    Nov 8, 2006
    6
    0
    Iran
    i want calculator program that it can do add,sub,div,mul
  2. sci-3d
    sci-3d Member
    Aug 23, 2006
    59
    0
    Did you mean the Simulator for the 8051?
    Please check edSim-51: http://edsim51.com/
  3. phalanx
    phalanx Member
    Oct 22, 2003
    405
    7
    New Hampshire, USA
    When is your assignment due?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. sirous
    sirous New Member
    Nov 8, 2006
    6
    0
    Iran
    i want it for next week
  6. sirous
    sirous New Member
    Nov 8, 2006
    6
    0
    Iran
    yes
    i want it can just do add,sub,mul and div
    and it can calculate until one number after point
    ex:
    35/4=8.7
  7. sirous
    sirous New Member
    Nov 8, 2006
    6
    0
    Iran
    yes
    for 8051
  8. Marks256
    Marks256 New Member
    Jul 14, 2006
    2,350
    9
    Minnesota, USA
    http://www.drpaulcarter.com/pcasm/
    Well, start programming!!!! If it is due next week, then you have a week to learn assembly, and then make(and debug) a complete calculator program...
  9. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    Also we don't mind helping but we won't do all the work for you.
  10. Marks256
    Marks256 New Member
    Jul 14, 2006
    2,350
    9
    Minnesota, USA
    http://www.pjrc.com/tech/8051/
    scroll down towards the bottom. There is a bunch of sample code at the bottom. There is also a pretty cool development board, too(didn't look at it much, though).
  11. masud58
    masud58 New Member
    May 14, 2004
    15
    0
    Dhaka
    a sample file from proteus which u want
    ************ LABCENTER ELECTRONICS ************
    ************ Proteus VSM Sample Design Code ************
    ************ Integer Calculator ( 2K Code Limit) ************
    #include <intrins.h>
    #include <reg51.h>
    #include "calc.h"
    //Variables
    static data LONG lvalue;
    static data LONG rvalue;
    static data CHAR currtoken;
    static data CHAR lasttoken;
    static data CHAR lastpress;
    static xdata CHAR outputbuffer[MAX_DISPLAY_CHAR];
    VOID main (VOID)
    //Initialise our variables and call the
    //Assembly routine to initialise the LCD display.
    { lvalue = 0;
    rvalue = 0;
    currtoken = '=';
    lasttoken = '0';
    initialise(); // Initialize the LCD
    calc_output(OK);
    calc_evaluate();
    VOID calc_evaluate()
    { CHAR data key;
    INT data i;
    CHAR xdata number[MAX_DISPLAY_CHAR];
    CHAR xdata *bufferptr;
    // Clear the buffer before we start.
    for (i = 0; i <= MAX_DISPLAY_CHAR; i++)
    { number = ' ';
    bufferptr = number;
    for (;;)
    { key = calc_getkey();
    if (calc_testkey(key))
    // Key test positive for digit so we read it into the
    // buffer and then write the buffer to the screen/LCD.
    // Size limit the number of digits - allow for termination
    // and possible negative results.
    { if (bufferptr != &number[MAX_DISPLAY_CHAR - 2])
    { *bufferptr = key;
    calc_display(number);
    bufferptr++;
    else
    // Key is an operator so pass it to the function handlers.
    // If we are just after startup or cancel then assign to lvalue
    // otherwise assign to rvalue.
    //Assign the value.
    if (lasttoken == '0')
    { lvalue = calc_asciidec (number);}
    else
    { rvalue = calc_asciidec (number);}
    //Clear the number buffer.
    bufferptr = number;
    for (i = 0;i <= MAX_DISPLAY_CHAR; i++)
    { number = ' '; }
    //Process the Operator.
    currtoken = key;
    if (currtoken == 'C')
    { calc_opfunctions(currtoken); }
    else
    { calc_opfunctions(lasttoken); }
    // Clear the outputbuffer for reuse on next operation.
    for (i = 0;i <= MAX_DISPLAY_CHAR;i++)
    { outputbuffer = ' ';}
    bufferptr = number;
    // Handle the equals operation here for brevity.
    // All we need do is preserve the previous operator in
    // lasttoken.
    if (currtoken != 0x3D) lasttoken = currtoken;
    lastpress = key;
    VOID calc_opfunctions (CHAR token)
    // Handle the operations. Lvalue holds the result and we test for
    // consecutive operator presses.
    { CHAR data result;
    switch(token)
    // Add.
    { case '+' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39)))
    { lvalue += rvalue;
    result = calc_chkerror(lvalue);
    else
    { result = SLEEP; } break;
    // Subtract.
    case '-' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39)))
    { lvalue -= rvalue;
    else
    { result = SLEEP;} break;
    // Multiply.
    case '*' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39)))
    { lvalue *= rvalue;
    else
    // Divide.
    case '/' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39)))
    { if (rvalue)
    { lvalue /= rvalue;
    else
    { result = ERROR;}
    else
    // Cancel.
    case 'C' : lvalue = 0;
    rvalue = 0;
    currtoken = '0';
    lasttoken = '0';
    result = OK; break;
    default : result = SLEEP;
    calc_output(result);
    ***** Utility Routines *****
    INT calc_chkerror (LONG num)
    // Check upper and lower bounds for the display.
    // i.e. 99999999 and -99999999.
    { if ((num >= -9999999) && (num <= 9999999))
    return OK;
    else
    return ERROR;
    VOID calc_output (INT status)
    // Output according to the status of the operation.
    // *Sleep* is used for the first op press after a full cancel
    // or on startup.
    { switch (status)
    { case OK : calc_display(calc_decascii(lvalue)); break;
    case SLEEP : break;
    case ERROR : calc_display("Exception "); break;
    default : calc_display("Exception "); break;
    LONG calc_asciidec (CHAR *buffer)
    // Convert the ASCII string into the floating point number.
    { LONG data value;
    LONG data digit;
    value = 0;
    while (*buffer != ' ')
    { digit = *buffer - 48;
    value = value*10 + digit;
    buffer++;
    return value;
    CHAR *calc_decascii (LONG num)
    // A rather messy function to convert a floating
    // point number into an ASCII string.
    { LONG data temp = num;
    CHAR xdata *arrayptr = &outputbuffer[MAX_DISPLAY_CHAR];
    LONG data divisor = 10;
    LONG data result;
    CHAR data remainder,asciival;
    INT data i;
    // If the result of the calculation is zero
    // insert a zero in the buffer and finish.
    if (!temp)
    { *arrayptr = 48;
    goto done;
    // Handle Negative Numbers.
    if (temp < 0)
    { outputbuffer[0] = '-';
    temp -= 2*temp;
    for (i=0 ; i < sizeof(outputbuffer) ; i++)
    { remainder = temp % divisor;
    result = temp / divisor;
    // If we run off the end of the number insert a space into
    // the buffer.
    if ((!remainder) && (!result))
    { *arrayptr = ' ';}
    // We're in business - store the digit offsetting
    // by 48 decimal to account for the ascii value.
    else
    { asciival = remainder + 48;
    *arrayptr = asciival;
    temp /= 10;
    // Save a place for a negative sign.
    if (arrayptr != &outputbuffer[1]) arrayptr--;
    done: return outputbuffer;
    CHAR calc_testkey (CHAR key)
    // Test whether the key is a digit or an operator. Return 1 for digit, 0 for op.
    { if ((key >= 0x30) && (key <= 0x39))
    { return 1;}
    else
    { return 0;}
    ***** I/O Routines *****
    CHAR calc_getkey (VOID)
    // Use the input routine from the *Keypad_Read* assembly file to
    // Scan for a key and return ASCII value of the Key pressed.
    { CHAR data mykey;
    do mykey = input();
    while (mykey == 0);
    return mykey;
    VOID calc_display (CHAR buf[MAX_DISPLAY_CHAR])
    // Use the Output and Clearscreen routines from the
    // *LCD_Write* assembly file to output ASCII values to the LCD.
    { INT data i = 0;
    clearscreen();
    for (i ; i <= MAX_DISPLAY_CHAR ; i++)
    { if (buf != ' ')
    { output(buf); }
  12. Marks256
    Marks256 New Member
    Jul 14, 2006
    2,350
    9
    Minnesota, USA
    And you couldn't have linked to the original source because....?
  13. sirous
    sirous New Member
    Nov 8, 2006
    6
    0
    Iran
    thanks a lot masud
Share This Page
