    Dismiss Notice
C program to reverse a number.
Discussion in 'Microcontrollers' started by Parth86, Aug 24, 2017.
  1. Parth86
    Parth86 Member
    Dec 25, 2011
    515
    5
    Hi
    I am able to write program that print reverse number example 10 9 8 7 6 5 4 3 2 1
    Code (c):
    #include <stdio.h>
    int main()
        int i =10;              / decleration of variable
        while(i>=1)
            printf("%d \n", i);
            i--;
        return 0;
    Now I want to write c program that reverse the number entered by the user and then prints the reversed number on the screen. For example if user enter 123 as input then 321 is printed as output. I have seen some program on internet but I don't understand the logic behind program. so looking help with basics
  2. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,022
    317
    Brisbane Australia
    ONLINE
    Something like,
    Code (text):
        unsigned char i,str="12345";
        for(i=0;i<5;i++){
            printf("%d \n", str[4-i]);
    You can do a for that decrements but it's a little messy with unsigned numbers.
  3. ci139
    ci139 Active Member
    Apr 12, 2012
    404
    34
    Code (text):
    #include  <stdio.h>
    int main(void)
    { __int64 x=76543210;
      __int64 y=0;
      __int64 g=0;
      while(x>0)
      { g=10*g+9;
        y=10*y+x%10;
        x=x/10;
      printf("x = %d\n", x);
      printf("y = %d\n", y);
      printf("g = %d\n", g);
      return 0;
    x = 0
    y = 1234567
    g = 99999999
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Cicero
    Cicero Active Member
    Nov 21, 2014
    335
    36
    UK
    Here's a quick reverse integer function with comments.
    Code (c):
    int reverse(int x) {
        int temp, digit, res = 0;
        while (x != 0) {
            // mod 10 gets digit
            digit = x % 10;
            // shift previous result over and add the newest digit - store temp for overflow comparison
            temp = res * 10 + digit;
            // prevent int overflow by checking if reverse operation is the same
            if ((temp - digit) / 10 != res)
                return 0;
            // not overflow, so store new result for next interation
            res = temp;
            // remove digit from original number, shift down
            x /= 10;
        return res;
  6. Parth86
    Parth86 Member
    Dec 25, 2011
    515
    5
    I said that I have seen many programs on internet and I am just asking for basic understanding. suppose how do you do manually than using by program. so I think I have to understand what's happening and than I want to go with program.
  7. Cicero
    Nov 21, 2014
    335
    36
    UK
    That's why I added the code comments, for understanding. Its just maths. It makes me think you don't understand what a modulo operation is?
    The method is to do one digit at a time from the integer until nothing is left.
    From the input number, get the smallest to biggest digit using modulo 10, and divide by 10 to shift the integer down.
    For the reversed result, you do the opposite. Use the digits acquired above but add them to the result after multiplying by 10 for each one.
    Example 345, need to get the 5, use module 10. Then need the 4, so take 345/10 = 34, and module 10 = 4. Need the 3, so take 34/10 mod 10 = 3.
    For the result you just do the opposite with those numbers. 5, then when you have the 4, take 5*10+4=54, when you have the 3, 54*10+3.
    Example: Start x = 345, res=0
    First loop:
    • digit = x % 10 = 5
    • temp = res * 10 + digit = 0*10 + 5 = 5
    • if ((temp - digit) / 10 != res) = if ((5-5)/10 != 0) = if (0!=0)
    • res = temp = 5
    • x/=10 = x/10 = 345/10 = 34
    Second loop:
    • digit = x % 10 = 34%10 = 4
    • temp = res * 10 + digit = 5*10 + 4 = 54
    • if ((temp - digit) / 10 != res) = if ((54-4)/10 != 5) = if (5!=5)
    • res = temp = 54
    • x/=10 = x/10 = 34/10 = 3
    Third loop:
    • digit = x % 10 = 3%10 = 3
    • temp = res * 10 + digit = 54*10 + 3 = 543
    • if ((temp - digit) / 10 != res) = if ((543-3)/10 != 54) = if (54!=54)
    • res = temp = 543
    • x/=10 = x/10 = 3/10 = 0
    No forth loop because x=0
    return result = res = 543
    • Like Like x 1
  8. ci139
    ci139 Active Member
    Apr 12, 2012
    404
    34
Share This Page
