    Dismiss Notice
Build a GPS receiver?
Discussion in 'General Electronics Chat' started by mindctrl, Jan 17, 2005.
  1. mindctrl
    mindctrl New Member
    Dec 3, 2004
    73
    0
    Hi guys,
    I was just wondering, and I know this is probably a really complicated project that I wouldn't want to get involved with, but I'm going to ask anyway because I am curious. Has anybody ever heard of a project where you build your own GPS receiver?
    I looked on Google and I couldn't find anything. I found a whole bunch of information about making custom cables for your GPS, etc. but nothing to deal with the actual fabrication of a GPS receiver.
    I ask this question because eventually I want to build a project that needs to have a relatively exact location sensor in it, using the GPS system. I don't want to bother with using a big hunk of equipment that has tons of features I don't need. I just need something that maybe has a 4x20 LCD display readout with a couple of buttons to toggle through menus.
    I look forward to your knowledgeable responses. :) Thanks and have a great night. Happy Martin Luther King Day!
    --mindctrl
  2. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Building your own GPS receiver would be quite tough job. It is very complicated and would be rather expensive than what is readily avilable. All you need to do is poll the receiver through its serial port using any microcontroller interface, get the readings, decode it and display it on LCD which is also interfaced with the uC. Don't go for building the receiver yourself.
  3. mindctrl
    mindctrl New Member
    Dec 3, 2004
    73
    0
    What exactly about it is so tough? Are there special "encoder" chips that are only available to certain manufacturers with a government contract, or something? I guess what I'm trying to say, is how exactly is this such a hard project? How would it be any different from building any other kind of receiver? What kind of complications are there?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. bmcculla
    bmcculla New Member
    Sep 5, 2003
    898
    0
    California, USA
    The High frequency stuff is not easy - lots of math and lots of testing required. I'ts also really hard to buy that sort of IC except in high volumes. These sorts of ICs also tend to be in tiny packages that arn't hand solderable.
    If you want GPS you'll probably have to shell out some money for a pre built module. Using a module shouldn't be too hard though. I think Sparkfun.com has some.
  6. checkmate
    checkmate New Member
    Aug 24, 2003
    402
    0
    Well, maybe you are googling with the wrong keywords. I checked "GPS Development Kit" and received lots of related hits.
  7. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    If you don't know why it's difficult, you probably don't have a chance of making one from scratch!, assuming you could get the special chips required?. Certainly doing so would cost a great deal more money than buying one.
    Would you build your own PC motherboard from scratch?, or your own Pentium 4 processor?.
    As already suggested, you can buy GPS modules which you can then build into your own projects, this makes for a relatively simple construction, with all the expensive, complicated, parts ready done.
  8. TheOne
    TheOne New Member
    Oct 30, 2004
    464
    0
    USA
    Like Nigel said a GPS receiver won't be easy. If you never worked around designing circuits at 1600MHz before and the necessary test equipment, you will have very little chance to get it working. Also GPS receivers must have ultra low noise front-ends as you dealing with signal levels -120dBm and lower. Then there is still the decoding etc. etc.
    I posted my design of a GPS amplifier before. The combline filter in there needs 1pF variable capacitors to do the tuning on the resonators. So you can get an idea how critical things become at higher frequencies, not to mention pcb layout. Without a network analyzer to align the filter it would be almost impossible to get the alignment correct.
  9. Dark_knight16
    Dark_knight16 New Member
    Dec 3, 2008
    1
    0
    GPS receiver
    HI guys
    this is mahesh from India,
    i Hv read Abt GPS and i know how it works
    i just want to know how can i build one????
    on of the posts frm this site itself said that we get GPS modules???
    frm where can i find those
    My receiver would hv small LCD touch screen display which would show me current time,position and i shoul be able to zoom in & out just a bit.& it should be able to guide me where i want to go
    pls awaiting anyones reply
    its urgent (its my project guys)
  10. Lantz
    Lantz New Member
    Dec 3, 2008
    5
    0
    Sweden
    You can buy a single 20-channel gps receiver IC for $40 at sparkfun. Pretty nice! Doesn't feel like it's worth the effort of designing your own (which would probably cost thousands of dollars in equipment) when they come this cheap...
  11. Ubergeek63
    Ubergeek63 Well-Known Member
    Apr 16, 2008
    1,886
    37
  12. peterson98908
    peterson98908 New Member
    Feb 27, 2009
    2
    0
    GPS Project
    Does anyone have any information on buying a GPS or building a GPS. Please email me and let me know if you are willing to help me. PLLEEEAAZZZZZEEEE!
    Bill
  13. picbits
    picbits Well-Known Member
    Jan 29, 2007
    2,003
    95
    Northants, United Kingdom
    Buy a GPS Serial "mouse" off Ebay from Taiwan for $10
    Hook up to a serial port
    Learn NMEA codes
    Interface with a microcontroller.
  14. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    eBay for buying, as for building just buy one.
  15. ankit aswale
    ankit aswale New Member
    Jul 8, 2010
    1
    0
    we are the students of E&TC we want an minor projet details on gps receivers immediately
    thanku
  16. peterson98908
    Feb 27, 2009
    2
    0
    GPS receiver
    Please get a hold of me for the GPS project at billp@heyl.net.
    thanks
Share This Page
