I stumbled across this and am shocked at what happened to this guy.
That's total baloney!
I played with mercury as a schoolkid...
So did I, heh! Maybe that explains my lack of short-term memory. What were we talking about?
There is a miniscule amount of mercury in a CFL bulb, and it's in vapor form, so it blows away. If is was lying around in droplets, a magnet wouldn't help.
Apparently, if you swallow a drop of Mercury....it passes through your body and exits through your bum seconds later. Shattered into lots of pieces obviously. Then you need a magnet to collect all.
I cannot confirm this as I have not tried it. Sounds like a cool party trick though.
Cheery bye
T TE
Brownout said:There is a miniscule amount of mercury in a CFL bulb, and it's in vapor form, so it blows away. If is was lying around in droplets, a magnet wouldn't help.
Sceadwian said:According to this website, it's an average of 4mg, I wouldn't quiet call that minuscule,
Also it doesn't just blow away unless you're outdoors in a good breeze
the specific gravity of mercury even in a vapor form will cause it drop to the ground (less ambient air flow) and remain in the environment until diffused by traffic
I'm just guessing but I'd imagine it will oxidize possibly to a particulate form
There are documented cases of mercury poisoning (especially of young children) I found one where a case of 8 full sized 40 watt tubes were broken in a storage shed which was cleaned up, however the mercury stayed in the environment and the child suffered mercury poisoning (non fatal) because they played in the area. Not the increase scale of the mercury from 8 full sized tubes.
Wikipedia said:Fluorescent lamps contain mercury which is released when bulbs are broken. Mercury in bulbs is typically present as either elemental mercury liquid, vapor or both since the liquid evaporates at ambient temperature.[75] When broken indoors, bulbs may emit sufficient mercury vapor to present health concerns, and the U.S. Environmental Protection Agency recommends evacuating and airing out a room for at least 15 minutes after breaking a fluorescent light bulb.[76] Breakage of multiple bulbs presents a greater concern. A 1987 report described a 23-month-old toddler who suffered anorexia, weight loss, irritability, profuse sweating, and peeling and redness of fingers and toes. This case of acrodynia was traced to exposure of mercury from a carton of 8-foot fluorescent light bulbs that had broken in a potting shed adjacent to the main nursery. The glass was cleaned up and discarded, but the child often used the area for play.[77]
Wikipedia said:^ Tunnessen WW Jr, McMahon KJ, Baser M (1987). "Acrodynia: exposure to mercury from fluorescent light bulbs". Pediatrics 79 (5): 786–9. PMID 3575038.
