    Dismiss Notice
AVR GCC - Any comfortable way of controlling single IO pins ?
Discussion in 'AVR' started by ItsMike, Sep 2, 2011.
  1. ItsMike
    ItsMike New Member
    Mar 3, 2011
    108
    3
    Hey everyone.
    I'm looking for a macro/function with no (or minimal) performance loss to control single IO pins using this syntax:
    Writing:
    PB0=<value>;
    Where value can be anything, any value not 0 would be regarded as 1 (logic high).
    Reading:
    <variable>=PB0;
  2. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    Such functions already exist within C, for both read and write. If you need anything within a few cycles of the chip speed for importance you can't use C, you'd have to use ASM.
  3. 3v0
    3v0 Coop Build Coordinator Forum Supporter
    Jul 14, 2006
    9,404
    227
    OKLAHOMA USA
    You can have some fun with this.
    Compilers should know how to use bit set, clear, and test instructions. But having any non zero value as one prevents the use of bit test.
    For fun compile this code and see which line results in the fewest instructions by looking at the ASM listing generated.
    Code (text):
      char a;
      PB0 = !!a; // first logical not converts to inverted bool, second un-inverts the value
      PB0 = ~!a; // first logical not converts to inverted bool, bit not un-inverts
      PB0 = a>0;
    All 3 lines should give the same result but the compiler is free to figure out how. Be sure to try it with optimization too.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. wkrug
    wkrug Active Member
    May 30, 2010
    271
    29
    Germany
    In Code Vision you can do this by PORTB.0=1; // Will set the first Pin of PORTB
    If that should effect at GCC you should try yourself.
  6. Exo
    Exo Active Member
    Sep 18, 2003
    1,953
    1
    Belgium
    Code (text):
    //Macro's
    #define SetPin(Port, Bit)    Port |= (1 << Bit)
    #define ClearPin(Port, Bit)    Port &= ~(1 << Bit)
    //Allows you to do the following in code...
    SetPin(PORTB, PB3);   //Sets bit 3 on port B
    ClearPin(PORTA, PA1);  //Clears bit 1 on port A
    Accessing a single bit as a complete variable (as in PB0 = 0 for example) is not possible in true C. It's an extra gimmick added to some compilers but avr-gcc follows the true C standard so the above method is the only option. It does end up as sbi, cbi instructions tough, the compiler is smart enough for that.
    In order to set the pin on any nonzero value , and clear it when zero do the following:
    Code (text):
    if (Value)
        SetPin(PORTA, PA1);
    else
    If you need to use this a lot, you can put the whole thing in a macro like this:
    Code (text):
    #define PinVal(Port, Bit, Val)    Port = Val ? Port | (1 << Bit) : Port & ~(1 << Bit);
    PinVal(PORTB, PB3, Value); //Will set bit 3 on port B if Value is nonzero, clear otherwise.
  7. ItsMike
    ItsMike New Member
    Mar 3, 2011
    108
    3
    This is what i'm using right now, too bad I can't access a single bit as a complete variable.
  8. External Solutions
    External Solutions New Member
    May 4, 2014
    1
    0
    These are my macros:
    Code (text):
    #ifndef cb
        #define cb(reg, bit)    reg &= ~(1<<bit) //clear bit
    #endif
    #ifndef sb
        #define sb(reg, bit)    reg |= (1<<bit) //set bit
    #endif
    #ifndef rb
        #define rb(reg, bit)    (reg & (1<<bit)) //read bit
    #endif
    and examples of use:
    Code (text):
    int main(void)
        sb(DDRB, 0); //port b 0 as output for led
        while(1)
            if( rb(PIND, 2) )
                sb(PORTB, 0); //led on
            else
                cb(PORTB, 0); //led off
  9. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
Share This Page
