    Dismiss Notice
AVR 2313 Accurate 1 second clock
Discussion in 'AVR' started by cleoestrada, May 31, 2006.
  1. cleoestrada
    cleoestrada New Member
    May 25, 2006
    4
    0
    I am trying to make a 1 sec period using AVR AT90S2313 but the timing is not accurate - 1 second is sometimes fast. Can some one show me a code in BASCOM AVR or assembly to create very accurate 1 sec clock, pls.
    Thx
    Cleo
  2. mramos1
    mramos1 Active Member
    Sep 15, 2005
    2,403
    9
    Boynton Beach, Florida USA
    cleoestrada: You can visit bastoc.com and pull the RVKBASIC free version (Atmel BASIC compiler) and see if it is work correctly?
  3. Papabravo
    Papabravo Well-Known Member
    Mar 9, 2006
    2,889
    25
    Michigan, USA (GMT-5)
    If the processor's clock is off by a little bit then your one second time can be off by quite a bit. Start with the processors time base, then check your algorithm and peripherals for counting the correct number of cycles. Lastly, if you are using interrupts, dont forget to account for the interrupt response latency.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. bibinjohn
    bibinjohn New Member
    May 7, 2006
    47
    0
    void delay_ms(unsigned char time_ms)
    unsigned short delay_count = F_CPU / 4000;
    unsigned short cnt;
    asm volatile ("\n"
    "L_dl1%=:\n\t"
    "mov %A0, %A2\n\t"
    "mov %B0, %B2\n"
    "L_dl2%=:\n\t"
    "sbiw %A0, 1\n\t"
    "brne L_dl2%=\n\t"
    "dec %1\n\t" "brne L_dl1%=\n\t":"=&w" (cnt)
    :"r"(time_ms), "r"((unsigned short) (delay_count))
    This is an accurate delay generator.
  6. johnsmith123
    johnsmith123 Member
    Sep 24, 2005
    141
    2
    avr 1 second delay
    Why don't you just use the simulator in avr studio?
    here is a routine from avr240.asm (slightly modified)
    ;1 second delay on 4 MHz clock
    delay:
    ldi R20,21
    delay1:
    ldi R19,252
    delay2:
    ldi R18,251
    delay3:
    dec R18
    brne delay3
    dec R19
    brne delay2
    dec R20
    brne delay1
    ret
  7. mramos1
    Sep 15, 2005
    2,403
    9
    Johnsmith123.. Thanks, Nabbed a copy for myself. Thank, will mosy likely use that in my next Atmel project (just inline ASM it)..
    Seems like I need 1 second delay lately. The pause 1000 is fine with a EXT OSC, will see if it is better for the little extra work.
  8. cleoestrada
    May 25, 2006
    4
    0
    RE: 1 Sec time delay
    Thank you all for your kind help.
    Cleo
  9. johnsmith123
    johnsmith123 Member
    Sep 24, 2005
    141
    2
  10. agent420
    agent420 New Member
    Jun 1, 2006
    73
    0
    3rd stoned from the sun
    Check out this RTC tutorial over at avrFreaks; it explains the how to configure the timers for accurate delays and how to make a Real Time Clock using the system clock frequency.
    The examples are in C but should be easily ported to Bascom.
    You might need to register (free) at avrFreaks, but it's a great resource for all things avr.
  11. Rakesh hasija
    Rakesh hasija New Member
    Aug 22, 2008
    2
    0
    help me out
    Plz anybuddy help me out,I want to generate 1sec delay using timers of atmega32 in assembly lang,i m using avr studio.plz anybuddy reply me with code.
  12. CCD
    CCD New Member
    Jul 27, 2008
    74
    1
    Chennai, India
  13. philba
    philba New Member
    Mar 12, 2006
    1,886
    8
    Seattle
    I think it's very hard to build an RTC using delays. While it is easy to create precise delays, you have to factor in the code that calls the delays. In addition, you will have different execution paths depending on program logic and it becomes very difficult to take into account every cycle. Even an instruction or two off starts to add up.
    It's much better to use timers to make the time measured independent of the code execution path. Care needs to be taken to ensure that no clock cycles are lost.
  14. Rakesh hasija
    Aug 22, 2008
    2
    0
    actuaaly i m using timer1 which is 16 bit of atemega 32 and having external crystal of 10mhz.but i can't have idea abt prescalers,i want to generate 1 sec delay after one second my overflag should get set.u have code for that plz reply as sun as possible.
  15. philba
    philba New Member
    Mar 12, 2006
    1,886
    8
    Seattle
    I don't have code for that. If I were you, I would take a close look at the datasheet and do some experimenting if it is not obvious.
    Another approach is to accumulate smaller units like 100 mS. Accumulate 10 of those to make 1 second. There are many ways to do what you want.
Share This Page
