ATMega16l and Nokia5110 LCD issue
darkestdream
I made a simple program wich has to turn all the display black and...it doesn't work. The LCD seems dead. Just the backlight is on. Here's the code
#include <avr/io.h>
#define F_CPU 40000UL  //4 MHz
#include <math.h>
#include <avr/interrupt.h>
#include <avr/power.h>
#include <avr/sleep.h>
typedef struct
   unsigned int bit0:1;
   unsigned int bit1:1;
   unsigned int bit2:1;
   unsigned int bit3:1;
   unsigned int bit4:1;
   unsigned int bit5:1;
   unsigned int bit6:1;
   unsigned int bit7:1;
} _io_reg;
#define REGISTER_BIT(rg,bt)((volatile _io_reg*)&rg)->bit##bt
#define LCD_RST REGISTER_BIT(PORTB,0)
#define LCD_DC REGISTER_BIT(PORTB,1)
#define SS_LCD REGISTER_BIT(PORTB,2)
int main(void)
   ioinit();
   spiinit();
   lcdinit();
   lcdclear();
   lcdfill();
   while(1)
void sleep30ms()
   OCR1A=120;
   TCCR1B|=(1<<CS12)|(0<<CS11)|(1<<CS10)|(1<<WGM12);
   while(OCF1A==0)
   TCCR1B &=~(1<<CS12);
   TCCR1B &=~(1<<CS10);
   TCNT1=0;
void ioinit()
   DDRB|=(1<<0)|(1<<1)|(1<<2);
void spiinit()
         //SCK   MOSI   !SS
   DDRB |= (1<<7)|(1<<5)|(1<<4);
      //enable-master-fclk/128
   SPCR =0x53;
void lcdinit()
   LCD_RST=0;
   sleep30ms();
   LCD_RST=1;
   lcdcommand(0x21);   //extend command
   lcdcommand(0x0B);   //contrast
   lcdcommand(0x04);   //temp coeff
   lcdcommand(0x14);   //bias mode 1:48
   lcdcommand(0x0C);   //lcd in normal mode
   lcdcommand(0x20);   //normal mode
   lcdcommand(0x0C);   //normal display
void lcdcommand(char data)
   LCD_DC=0;
   SS_LCD=0;
   spiout(data);
   SS_LCD=1;
void lcddata(char data)
   LCD_DC=1;
   SS_LCD=0;
   spiout(data);
   SS_LCD=1;
void spiout(char data)
   SPDR=data;
   while(!(SPSR & (1<<SPIF)))
void lcdclear()
   unsigned int i;
   for(i = 0; i < 504; i++)
      lcddata(0x00);
void lcdfill()
   unsigned int i;
      lcddata(0xff);
