magnetman12003
I wish to construct a 10 inch diameter, .75 inch thick air core magnet wire loop that can be plugged directly into a 120 volt AC wall socket.
This coil must be strong enough to radiate its 60 hz magnetic field outwards at least 3 feet. It should not warm up with continuos use.
I plan to spin a disk type permanent magnet within that radiated oscillating magnetic field. Check out "tracmag" on the U tube. I believe his powered tracmag loop coil is made that way.
All advice as to AWG magnet wire size, number of turns, amount of wire in feet needed will be greatly appreciated.
