Hello!
Could I ask for some clarification regarding the way it is possible to program the 8051 family, specifically the AT89C51 and the AT89S51?
I think I've (not for the first time) confused myself!
Here is what I understand:
All the modern AT89x5x uC are Flash based but that doesn't mean they are all programmed the same way -
AT89C51 - require high voltage (12v) programming via a parallel process, which can be through a pre-programmed device or via a parallel port on a PC.
For eg **broken link removed**
This board that uses a serial port which is a requirement in my case.
I ask clarification because the AT89c51 fact sheet mentions 5v marking on certain chips but doesn't go into any details about programming!
AT89S51 - can be programmed using simple (low-voltage) in-circuit programmers or traditional (12v) programmers
An example of this would be **broken link removed**
The only problem I have with this is that it is parallel port based which I don't have on my machine - is there a serial port or even USB equivalent?
So is that it? C types require a 12v programming while S types can employ either?
