8051
mstechca
Perhaps I should add something.
It seems that all over on the internet, when I look for code for the at89c2051 (an 8051 compatible microcontroller), I see code, but I also see lines similar to the following in some code:
SETB 1.1
CLR 3.1
I downloaded the entire instruction set for my microcontroller from Amtel, and they gave me opcode equivalents for the commands, but not for the port numbers. I assume something is generic with them.
The parameter for each command is 8-bits according to the document. How do I convert the port outputs (1.1, 3.1, etc) to the correct ascii value? There is no site so far that shows me this.
AT89C2051 has only port 1 and port 3. Port 1 has eight pins and port 3 has only seven pins. The LSB is called bit 0 and the MSB is bit 7.
SETB and CLR are bit operations that operates on one single bit.
SETB 1.1 = Set bit 1 of port 1
CLR 3.1 = Clear/reset bit 1 of port 3
I already know that.
Let me redefine my question.
If I were to connect my circuit to the computer through the parallel port, what exact code must be sent from the computer to the at89c2051 to turn P1.0 on?
Please don't use SETB, because I want to know in Bits and bytes.
OK, in hex SETB = D2 and Port 1.0 has an address of &H90.
So SETB 1.1 = D2 90
But the above is already stretching my knowledge of 8051 to its limit. I'm afraid I can't offer much help to you furthur. :(
thanks. Now if I could figure out the rest of the ports, I should then be set.
Presumably the datasheet will explain it all?.
Why did you chose this processor?, as you appear to know nothing about it! (as I don't).
reply
Nigel, sometimes hobbyist get board of the same microcontroller and like to explore other options.
