8051 temperature control codes needed !
The Light
hello every1
Im trying to construct a fan which works based on sensing the surrounding temperature.
I need assembly.L codes for the 8051 to make it able to control the temperature-sensor system connected to 8051 pins.
note:
- no external memory used
- the temperature-sensor system circuit is based on (LM35 transistor , and LM358 amplifier)
- this is the first time i use 8051 and the assemly.L
if more details needed , i will put the whole project circuit
thx for helping :)
well...
The Light said:
hello every1
note:
thx for helping :)
Well.. good try...
whatever you are demanding.. you'll be getting at ...
www.freewebs.com/maheshwankhede
these are the best interfacing tutorials you can ever get.. on 8051... along with circuit diagram and assembly & c code...
regards,
simrn..:)
The Light said:
hello every1
thx for helping
one more thing.. the tutorials that you shall be seeing in above website... you can change LM 358 by op amp 741...
second thing is that.. LM 35 is temperature sensor ( transistor like) .. and not just a transistor..
the design of opamp is shown on page https://www.freewebs.com/maheshwankhede/sensors.html
regards..
simran:)
thx Simran for the help
but the problem is i dont know how to program, this is the first time i use assembly language and i dnt have alot of time to MASTER programming.
i know the basics only, and everytime i search for the explanation i find the basics only, i need some advices on how to begin programing, what i have to program, and what r the steps, etc..
so i need a real help here
thx
1/ no
2/ yes
3/ 4 dayz ago ( i actualy know the theory, but when i come to practical programming i dont know what to do, how to think , what codes to use)
thx
The Light said:
1/ no
2/ yes
thx
ok...
listen and understand the following steps:
1. get a chip from the market called 89s51 from the company called ATMEL... remember to buy 89s51 not 89c51... if possible...
2. make a programmer in your home using solder iron..and other equipments from website marked with '*'
'*' **broken link removed** %20USB.htm
www.8052.com/users/AT89S52InSystemProg/
the second programmer is also very very good but you are new in the field of controllers...
3. download raisonance assembler from 8052.com ... given on left hand side...
till now do this...
regards
simran...
realy thanks for helping , but at the moment i cant begin doing the ISP.
my program should be ready within 1 week.
i realy want to know how to think about making a whole program by my self , and how to think what code to use. but i dont know, i think it need alot of time to learn this
no problem
yes,
atleast one month is required to understand the internal architecture and interfacings...
but dont worry... i'll give you the circuit diag..
you buy the components and a solder iron...
wait for next reply...
regards,
simran...:)
responding of help...
oh.. you just need the program rather than circuit diagram...
Well, program should be compatible with ckt. diag..
1. i am sending you the attachment of block diagram... all you have to do is interface one thing with other with the fhelp of these tutorials...
2. codes are also given in this....
Basic circuit:
https://www.freewebs.com/maheshwankhede/basic.html
for adc.. just follow ADC 0804
https://www.freewebs.com/maheshwankhede/adcdac.html
for LM 35 temperature sensor..
for LCD display...
https://www.freewebs.com/maheshwankhede/lcd.html
YOU CAN CHOOSE ANY COMPONENT YOU LIKE...:)
REMEMBER: DO NOT HASTE... IF YOU CANT MAKE FULL THING MAKE PART OF THAT THAT IS CORE...
REGARDS,
SIMRAN..
  • New Microsoft PowerPoint Presentation.pdf
EVERYBODY!!!
i need these codes urgently , the oject submition after few dayz !
this is the schemac :
plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz help meeeeee !! :(:(:(:(:(:(:(:(:(:(:(:(:(
thats what i'v done untill now :
PWM code :
Org 0H
sjmp start
org 0BH
TIMER_0_INTERRUPT:
JB F0, HIGH_DONE ; If F0 is set then we just finished the high section of the
LOW_DONE: ; cycle so Jump to HIGH_DONE
SETB F0 ; Make F0=1 to indicate start of high section
SETB P1.0 ; Turn off LED
MOV TH0, R7 ; Load high byte of timer with R7 (pulse width control value)
CLR TF0 ; Clear the Timer 0 interrupt flag
RETI ; Return from Interrupt to where the program came from
HIGH_DONE:
CLR F0 ; Make F0=0 to indicate start of low section
CLR P1.0 ; Turn on LED
MOV A, #0FFH ; Move FFH (255) to A
CLR C ; Clear C (the carry bit) so it does not affect the subtraction
SUBB A, R7 ;Subtract R7 from A. A = 255 - R7.
MOV TH0, A ; so the value loaded into TH0 + R7 = 255
start:
MOV TMOD, #00H
SETB TR0 ; turn on timer 0
SETB EA ; Enable Interrupts
SETB ET0 ; Enable Timer 0 Interrupt
MOV R7, #160 ; set pulse width control to dim
LOOP:
SJMP LOOP ; go to LOOP
END
7-segment :
Mov dptr,#decodedtable ;load the decoded values
mov temp, a ;where temp is a temp variable
anl a, #0F0H ;we just need the higher nibble
swap a
movc a,@a+dptr ; load the decoded value for
; the number to display
mov 7segport, a ;7segport is the port where 7segments
;are connected
acall delay ;you need some delay here.. about 10ms
;or more.. you can adjust it when u run
;then enable the common pin here
setb common1 ;for first 7-seg
;now we send the lower nibble
mov a, temp ;restore the number form temp
anl a, #0FH ;mask the higher nibble to extract
;lower nibble only
movc a, @a+dptr ;load the decoded value for
;lower nibble
mov 7segport , a ;send the decoded value
setb common2 ;enable the common pin for
;second 7-seg display
decodedtable:
db (decoded values here)....
thats all i got , plzzzzzzzzzzz help me
Well,
Well,
i just want to say that all you require is not more than 2 days work for which you spent so many days..
the mistake you've done is that you were either not serious or a lot of pressure is on you for other work also..
it is better to take help of some hobbyist near your home..
Regards,
Simran..:)
Now also..
The Light said:
thats what i'v done untill now : ........
Now also , i ask you to follow my suggestion..
see my previous post where i had given my links to freewebs.com ..
download all the four..
take their print out after converting it into word format..
and take the help of some college seniors to understand them..
all is there in that..
Remember, if you'll not do this .. I feel you'll waste your time..
Remember one more thing , even if u not fully make this project and submit small modules or parts.. then also your teacher might be happy.. atleast you've applied some effort.. without help of any other..
Regards,
Simran..
The Light said:
EVERYBODY!!!
Adding my comments.
A post like the included quote will NOT get you the response you are asking.
Most members just get irritated when they see this sort of post.
Basically,
You should have started the assignment earlier or you should have sufficient tuition to enable you complete the assignment with just a little help from the forum.
Anyway, good luck with you project.
What has..
See..
What has happened has happened..
now look at the following links and convert it into word format..
and study carefully for two days..
take help of this forum..
Basic circuit:
for LCD display...
i hope you should start your work..
Regards,
Simran..:)
ok thanks , i want to tell u that i hav a group of 10 person.
but im doing 80% of the job ( hardware + software ) , thats why
thank u anyway
this is why I tend not to help students. simran, you have more patience than I. I say point them in the right direction, once. if they can't get there from that, they should switch to liberal arts...
Let's try
i hope you are right..
but i feel that embedded systems and microcontrollers are one of the good fields.. the person can make his career of.. and enjoy his work..
Lets try best.. so that other people can take maximum out of this field..
Hope so..
Regards,
Simran..:)
