8051 assembly codes for send&recieve AT_commands by microcontroller&mobile
ritchie
hi
i 'm working on a project to control a few relays with a mobile sms , i want to interface a mobile sms to a 8051 micro , i need help about sending at_commands by micro to mobile in 8051 assembly codes,
thanks a lot
Hi my dear friend& thanks for your answer, but i want to know how can i send for example : AT+CMGR=1 from micro to mobile , what 's the assembly codes for sending this command to mobile
thanks a lot
I can supply the code in C if you require. Why asm?
Make a call that sends what in the Acc to the serial port
Code the command in prg memory and terminate in zero.
Repeat the send command from the first position until zero is detected and send ASCII 13 (carriage return) instead.
In C / pseudo code
char output[10]; //make an array to handle the length of what you want send.
sprintf(&output,"AT+CMGR=1"); //put the command into the array
while (output!=0) // send until NULL (0) is encountered
send output'
send (13); // send carriage return (your return key on the keyboard)
You may then want to check the modem returns "OK" in line with the AT command spec for your modem.
This can be complex as each modem differs and you need to handle exception to how the modem replies
