68hc12
Can I connect the amplifier straight to the input of the 68hc12? If I do will it damage it or will it be fine?
The amplifier will be single rail of +5v
Nigel Goodwin said:
I suggest you add a series resistor to limit the current, just in case the pin should get set as an output!.
I think as soon as it's turned on it's an output before the code instructs the port to become an input... I think
Will a resistor of few KOhms be fine or should this current be measured and resistor judged accordingly? I don't have immediate access till midway through next week which is a pain
[quote="carlosthejackle2001]I think as soon as it's turned on it's an output before the code instructs the port to become an input... I think
Will a resistor of few KOhms be fine or should this current be measured and resistor judged accordingly? I don't have immediate access till midway through next week which is a pain[/quote]
~1K will do.
That would be rather a stupid design! - PIC's are inputs by default, and you have to set them to be an output. I can't imagine any manufacturer doing it the other way round?.
hmm..in atmel 89 series (atleast in 89s52/89s8252) u have to write 1 to the port for it to become i/p, otherwise it is output by default afaik..
