Hello I m new here, this is my first thread
I have question about RF link, what is the difference between VHF and UHF transmission range.
example : I have to transmit data from point A to point B, and i have the possibility to transmirt at 50MHz, or at 433MHz.
If the Tx output power is the same ( exemple 30db), the receiver sensibility is the same also (exemple -70db), and if I use a simple dipole antenna (+3dbi) in transmission and reception in the same cases (at 50 and 433MHz), what is the best range between this two transmissions ???
If I use RF link budget calculator, the range of 50Mhz transmitter is greater than 433MHz, but RF calculator (like this : **broken link removed**) calculate range in line of side conditions but, in my application, i have two conditions :
1/ No objects between Tx and Rx, but i need distance up to 5 miles (5 to 6 miles) !!! ( curvature of the Earth = - 23 ft !!!)
2/ the height of Tx and Rx antennas are only 3 to 5 feets
So in this conditions, what is the best frequency : 50MHz or 433 MHz ?
If i dont"'use directive antennas, how much Tx power is necessary to cover this distance ?
Thks
Thks
