Primary coil is flat wound 1/4" copper tubing. $200
Secondary coil is 950 turns of #20 enamel coated copper wire 10.5" diameter. $200
Spark gap is variable speed vacuum fan RQ gap. $150
3 Capacitors are .01 uf 40,000. volts each. $100
Top load is 36" diameter stainless steel sphere. $500
High Voltage transformer is 240 Volt 60 amps input, multi tap output 14K, 15K, 16K, 17K volts. $500.
