This one's baffling me.
Why can't I use GPIO3 as an input? The code below works using GPIO5 as the Serial input line.
It also works if I change to GPIO4:
But as soon as I try GPIO3, I get continuous duplicate characters coming in - I think it's reading lows continously. I did add some code at one point to send a 1 or 0 via RS232 to tell me the level of GPIO3 and it worked fine as I alternated between Vdd and Vss. So why isn't it working from the MAX232? Why does it work on GPIO4 and 5 but not 3?
What's different about GPIO3 as an input compared to GPIO4 and GPIO5? Is there some configuration I'm missing? I've disabled MCLR (as far as I know).
Thanks,
David
SER_IN Equ 0x04
list p=12F675, b=8, c= 102, n=71, t=on, st=off, f=inhx32
#include <p12f675.inc>
errorlevel -302
__CONFIG (_INTRC_OSC_NOCLKOUT & _WDT_OFF &_BODEN_OFF &_CP_OFF &_CPD_OFF & _MCLRE_OFF)
;***** FLAGS
#define IF_SHORT flags, 0
#define FIRST_HALF flags, 1
#define HEADER flags, 2
#define VALID flags, 7
;***** VARIABLE DEFINITIONS
cblock 0x20 ;start of general purpose registers
Xmit_Byte ;holds byte to xmit
Rcv_Byte ;holds received byte
Bit_Cntr ;bit counter for RS232
Delay_Count ;delay loop counter
endc
SER_PORT Equ GPIO
SER_TRIS Equ TRISIO
SER_IN Equ 0x05
SER_OUT Equ 0x04
org 0x0000
RESET bcf STATUS,RP0 ; Bank 0
; clrf STATUS ;
clrf GPIO ; Init GPIO
movlw b'00000111' ;
movwf CMCON ; comparator off, digital I/O
bsf STATUS,RP0 ; bank 1
clrf ANSEL ; Digital I/O
movlw b'00101000' ;
movwf TRISIO ; Set GPIOs (1=input/0=output)
call h'3FF' ; get factory calibration value
movwf OSCCAL ; set OSCCAL calibration value
bcf STATUS,RP0 ; bank 0 |B0
call SER_INIT ; initialise serial port
; Startup beeps...
bsf GPIO, 0
call delay100
bcf GPIO, 0
call delay100
bsf GPIO, 0
call delay100
bcf GPIO, 0
loop
call Rcv_RS232
; movf Rcv_Byte
movlw '0'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bcf GPIO, 0
movlw '1'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bsf GPIO, 0
movlw '2'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bcf GPIO, 1
movlw '3'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bsf GPIO, 1
movlw '4'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bcf GPIO, 2
movlw '5'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bsf GPIO, 2
movlw '6'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bcf GPIO, 4
movlw '7'
xorwf Rcv_Byte,0
btfsc STATUS, Z
bsf GPIO, 4
movlw 'a'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep1
movlw 'b'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep2
movlw 'c'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep3
movlw 'd'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep4
movlw 'e'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep5
movlw 'f'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep6
movlw 'g'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep7
movlw 'h'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep8
movlw 'i'
xorwf Rcv_Byte,0
btfsc STATUS, Z
goto beep9
goto loop
beep1 bsf GPIO, 0
call delay100
bcf GPIO, 0
goto loop
beep2 bsf GPIO, 0
call delay250
bcf GPIO, 0
goto loop
beep3 bsf GPIO, 0
call delay250
call delay250
bcf GPIO, 0
goto loop
beep4 bsf GPIO, 0
call delay250
call delay250
call delay250
bcf GPIO, 0
goto loop
beep5 bsf GPIO, 0
call delay250
call delay250
call delay250
call delay250
bcf GPIO, 0
goto loop
beep6 bsf GPIO, 0
call delay100
bcf GPIO, 0
call delay100
bsf GPIO, 0
call delay100
bcf GPIO, 0
goto loop
beep7 bsf GPIO, 0
call delay100
bcf GPIO, 0
call delay100
bsf GPIO, 0
call delay250
call delay250
bcf GPIO, 0
goto loop
beep8 bsf GPIO, 0
call delay250
call delay250
bcf GPIO, 0
call delay100
bsf GPIO, 0
call delay100
bcf GPIO, 0
goto loop
beep9 bsf GPIO, 0
call delay250
call delay250
bcf GPIO, 0
call delay100
bsf GPIO, 0
call delay250
call delay250
bcf GPIO, 0
goto loop
;Serial routines
SER_INIT
BSF STATUS, RP0 ;select bank 1
; BCF SER_TRIS, SER_OUT ;set B6 as an output
BSF SER_TRIS, SER_IN ;set B7 as an input
BCF STATUS, RP0 ;select bank 0
; BSF SER_PORT, SER_OUT ;set SER_OUT high
RETURN
Rcv_RS232 BTFSC SER_PORT, SER_IN ;wait for start bit
GOTO Rcv_RS232
CALL Start_Delay ;do half bit time delay
BTFSC SER_PORT, SER_IN ;check still in start bit
GOTO Rcv_RS232
MOVLW 0x08 ;set up to read 8 bits
MOVWF Bit_Cntr
CLRF Rcv_Byte
Next_RcvBit CALL Bit_Delay
BTFSS SER_PORT, SER_IN
BCF STATUS , C
BSF STATUS , C
RRF Rcv_Byte , f
DECFSZ Bit_Cntr , f ;test if all done
GOTO Next_RcvBit
CALL Bit_Delay
MOVF Rcv_Byte, W
RETURN
Start_Delay MOVLW 0x0C
MOVWF Delay_Count
Start_Wait NOP
DECFSZ Delay_Count , f
GOTO Start_Wait
RETURN
;Bit_Delay MOVLW 0x18 ; Original setting in code - wasn't working reliably at 9600baud
Bit_Delay MOVLW 0x17
MOVWF Delay_Count
Bit_Wait NOP
GOTO Bit_Wait
RETURN
;End of serial routines
; Delay = 0.25 seconds
; Clock frequency = 4 MHz
; Actual delay = 0.25 seconds = 250000 cycles
; Error = 0 %
cblock
d1
d2
endc
;249998 cycles
delay250
movlw 0x4F
movwf d1
movlw 0xC4
movwf d2
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto Delay_0
;2 cycles
goto $+1
; Generated by http://www.piclist.com/cgi-bin/delay.exe (December 7, 2005 version)
; Sat Dec 31 06:04:07 2011 GMT
; See also various delay routines at http://www.piclist.com/techref/microchip/delays.htm
return
; Delay = 0.1 seconds
; Actual delay = 0.1 seconds = 100000 cycles
; Error = 0 %
; cblock
; d1
; d2
; endc
;99998 cycles
delay100
movlw 0x1F
movwf d1
movlw 0x4F
movwf d2
Delay_1
decfsz d1, f
goto $+2
decfsz d2, f
goto Delay_1
;2 cycles
goto $+1
; Sat Dec 31 06:07:36 2011 GMT
return
end
Thanks,
David
