Hi everyone. I am trying to make use of a 12-bit ADC to eventually read voltage values coming out of an accelerometer. But for now, just to get things going, I made a simple voltage divider out of resistors so that I can have a steady value. The problem is, I don't get a steady value in from the ADC, even capacitors all over the place. I'm getting values jumping +/- 10 out of 4096. I first tried this with the built-in ADC of a dsPIC30F4013 and got jumping values. I also tried using a MAX1246 12 bit ADC and got the same problems.
The power supply is the 5V supply out of my powered breadboard. It seems very stable. In addition, with the MAX1246 I was running it through a 3.3v regulator.
So my questions are:
1) Where is it important to put Capacitors?
2) Does anyone have any examples of how to make good use of a 12-bit ADC?
Thanks!
Thanks!
