| | #16 |
Jason: there's where I am not fully comprehending this whole jtag thing. it seems to me that some arm chips (lpc for example) have internal bootloader that once up on reset can receive data on its own. so why do we need such an expensive device? also, some of the schematics I have seen about jtag seems to suggest that it is taking signals from a db25 connector (rst, tms, tdi, tdo and tck), buffer them through a dual 232 chip and then dump them onto the same pins on the chip, with the rst signal reversed. that doesn't seem to be too difficult to wire up by oneself; and why do they need that buffering (for speed?)? so it seems to me the simplest thing would be to wire everything straight and then invert the rst signal (with a transistor). or if you are really cheap, program a dip8 pic to buffer it. then there seems to be some compatibility issues as to certain cables are compatible with certain chips but not others so I am not sure where to begin. | |
| | #17 |
i get lost also. but know of a link that will make you kinda happy lol give me one minute
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #18 |
Here are a few i have saved: Using LPC2000 flash ISP utility to program LPC2148 - Scientific, embedded, biomedical, electronics contents. SparkFun Electronics Never registered but will soon! Insiders Guides can you link me to that site? I know i saw it somewhere but lost it too lol um that last site you should like.... i think this is that dual rs232 thing http://www.olimex.com/dev/pdf/ARM-USB-OCD.pdf I would have used 1 : MAX238 since it has 4 rx/tx lines
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 21st June 2009 at 12:46 AM. | |
| | #19 |
I am still foggy on this whole flashing thing because I thought you could do that from within keil mdk. as to dual 232, you can try 244, which is dual 232 and they go for like a quarter each, give or take a few cents, .from what i could comprehend, there shouldn't be anything but a straight pass-through for those pins (other than rst - and why would they make that a reverse logic is beyond me anyway). | |
| | #20 |
just buy a programmer and rest assure it will work lol
| | #21 | |
I think you are thinking of the FT232 JTAG setups. The buffers are used for level shifting as JTAG has to be able to handle a range of voltages. You can leave off the buffers if all you care about is 3.3V operations. ...and the FT232 has special JTAG functionality, it doesn't just operate as a RS232 level shifter. I started making my own, but in cases like this, I think it's just better to pay the $50 for a ready made product. For me, it's not worth playing around with details rather than just getting everything up and running. I have the Olimex USB JTAG TINY. It's nice enough and works on the SAM and LPC chips. Only issue is only 2 hardware breakpoints which is inconvenient. Even if you could get the chips at a dollar a pop, there are some inconveniences that make it not so worth it for small projects. - 20 pin JTAG is a serious pain. I'm thinking of trying to minimize it to a 10pin header, but for someone who uses an 8bit micro with single pin debug/programming pin, even 10pins seems like a big hassle. - you need both a PLL and an external crystal. - the ARM cores run at 1.8V, so they have an onboard regulator that still requires you run traces from the internal regulator pins to the core power pins. It just makes routing boards for them complicated. I never liked those development boards with all of the stuff attached to them. A simple header board is just more useful to me, especially if you already have stuff you can wire to it. EDIT: It looks like routing core power isn't needed on the Cortex-M3 chips that I've looked at datasheets for. Now, I'm interested in these things. Looks like only Luminary Micro and ST have decent supplies out, at least available on Digikey. The prices aren't that fabulous, but they have a range of chips from small 20Mhz to large 72Mhz all in the same family.
__________________ Mark Higgins Last edited by DirtyLude; 21st June 2009 at 03:45 AM. | ||
| | #22 |
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 21st June 2009 at 03:50 AM. | |
| | #23 | |
__________________ Mark Higgins Last edited by DirtyLude; 21st June 2009 at 04:00 AM. | ||
| | #24 |
No. You need to get a compiler separately. I'm looking at Crossworks right now. It's all dependent on the level of integration you want and whether you want to use an FTDI chip or not.
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 21st June 2009 at 04:26 AM. | |
| | #25 |
I am actually thinking about just inverting the rest signal and directly apply the rest. as power supply, i thought the luminary chips are 5-v tolerant (on gpio) so it should handle anything this side of 5v. wouldn't that make level shifting less necessary? i also don't understand how a cable, which in theory, can be straight-through, can cause all those compatibility issues. | |
| | #26 |
luminary is by far the largest cortex-m3 supplier. they are now part of TI - hopefully the support will continue.
| | #27 |
I used mdk3.70 demo. free for download from Keil. so far, it has been great - I did have some issues with it not compiling correctly but a few uninstall / install fixed it. one limitation it has is 32k of code size but that's more than enough for me anyway.
| | #28 |
yeah thats what im using also. lol i dont even own a LPC yet but that demo and Isis(proteus) together works great... Millwood im running Isis separately from the uVision is there a way to set it as the debugger from within?
| | #29 |
yeah. but you will need to do some tweaking. 1) on the isis side, it needs to be set up for remote debugger - it is that way by default, under Debug. 2) you will need to download a dll from labcenter, vdmagdi.exe: http://downloads.labcenter.co.uk/vdmagdi.exe, and install it. 3) you will need to update tools.ini in uvision. it is under Options for Targets, and one of the debug tabs should have a drop down menu. if it doesn't have "Proteus VSM Debugger", you will have to manually add it by editing tools.ini. one of those lines will be TDRV0/1/2, .... just add one for you proteus VSM and have it pointed to VDMARM.dll installed in step 2). 4) the system will ask you for the ip address, type in 127.0.0.1 (your own machine), and 8000 is the port to use. then you are in. I have to tell you though that I don't use it myself. I find it easier to step through the C myself. | |
| | #30 |
thanks it took some time but working. I dont see the benifit of using it unless writing in ASM lol
| arm, cortex |
| ARM Cortex Microcontrollers? | dknguyen | Micro Controllers | 0 | 10th February 2009 12:37 AM |
| ARM Cortex-M3 DSP | dknguyen | Micro Controllers | 1 | 2nd February 2009 04:47 PM |
