    Dismiss Notice
ARM Cortex
Discussion in 'ARM' started by millwood, Jun 20, 2009.
  1. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    has anyone worked on those chips? they are the next gen from the ARM7/ARM9/ARM11 series and seems to be much faster than ARM7, and spans a wide performance spectrum.
    I am thinking more about the lower-end chips (Cortex-M3) than the higher end chips.
    Any thoughts?
  2. Papabravo
    Papabravo Well-Known Member
    Mar 9, 2006
    2,889
    25
    Michigan, USA (GMT-5)
    Worked on certainly covers quite a bit of ground. I've read the data sheet and I'm considering one for an application. Does that count?
  3. AtomSoft
    AtomSoft Well-Known Member
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    heh i think it depends on what your making. those kind of chips are are best for like RTOS (real time operating systems) .
    So yeah it depends on what you intend to use it for. Its a beautiful piece of hardware tho. If i was familiar with ARM and all this embedded stuff more i guess i would tinker with it :D
    http://www.arm.com/products/CPUs/ARM_Cortex-M3.html
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    they just seem to offer a lot of performance for the money: a 60mips (1.25mips / mhz @ 50mhz) chip for less than a dollar. That's pretty amazing.
  6. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    What quantity do you need to get them for $1
  7. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
  8. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    those are cortex-m3 chips in epoxy packaging, in 10k quantities, like you would have in a toy.
  9. Papabravo
    Mar 9, 2006
    2,889
    25
    It's like winning the Scottish Lottery. You get $1 per year for 1 million years.
  10. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Im thinking about starting with the ARM7 and staying there for a while :D
    Digi-Key - 568-2093-ND (NXP Semiconductors - LPC2102FBD48,151)
    seems like a good IC to use alot... of course ill start with a dev board tho. But when i do need to create something im sure that will fit in the requirements... if not there are a ton more and all are about same price as PIC.
    I know there isnt alot of support for ARM7 like PIC here but im sure ill learn alot and help alot.
    GREAT PLACE TO START:
    http://www.esacademy.com/myacademy/classdescription.php?category=&classid=35
    This is better tho:
    http://dkc1.digikey.com/us/en/tod/NXP/8-bitToARMConversion/8-bitToARMConversion.html
  11. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
  12. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
  13. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    They aren't "nextgen" per se. They are more like the ARM series but designed from scratch to be a microcontroller rather than a microprocessor. The M3 is the equivelant of the ARM7, and so on and so forth. I'm planning to use the M3 for the next thing I build because of the packaging and the programmer and IDE can be had for a fair price.
  14. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    jason: they all look like great mcus.
    dknguyen: which programmers are you thinking about? I am new to this jtag thing and haven't had it all figured out.
  15. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    I thought on architecture basis, cortex (harvard) is quite different from arm7 (von neumann). cortex (m3 at least) doesn't run the full arm instructions but just thumb(2?).
    I am just amazed at how much more you can get out of those chips.
  16. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
  17. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    Jason: there's where I am not fully comprehending this whole jtag thing.
    it seems to me that some arm chips (lpc for example) have internal bootloader that once up on reset can receive data on its own. so why do we need such an expensive device?
    also, some of the schematics I have seen about jtag seems to suggest that it is taking signals from a db25 connector (rst, tms, tdi, tdo and tck), buffer them through a dual 232 chip and then dump them onto the same pins on the chip, with the rst signal reversed. that doesn't seem to be too difficult to wire up by oneself; and why do they need that buffering (for speed?)? so it seems to me the simplest thing would be to wire everything straight and then invert the rst signal (with a transistor). or if you are really cheap, program a dip8 pic to buffer it.
    then there seems to be some compatibility issues as to certain cables are compatible with certain chips but not others so I am not sure where to begin.
  18. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    i get lost also. but know of a link that will make you kinda happy lol give me one minute
  19. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
  20. millwood
    millwood Banned
    Jun 17, 2009
    191
    2
    I am still foggy on this whole flashing thing because I thought you could do that from within keil mdk.
    as to dual 232, you can try 244, which is dual 232 and they go for like a quarter each, give or take a few cents, :).
    from what i could comprehend, there shouldn't be anything but a straight pass-through for those pins (other than rst - and why would they make that a reverse logic is beyond me anyway).
  21. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    just buy a programmer and rest assure it will work lol
Share This Page
