I have built a speedometer and gear indicator for my Suzuki motorcycle using a pic 16F876. That's is a simple circuit using 20 mhz clock. The speedometer signal come from VSS (vehicle speed signal) and goes direct to the pic pin and the signal from GPI (gear position indicator), which is a voltage, goes to another pin through a voltage divider. It's working but not very well because when I start the engine the readings are not steady. Does anyone could help me with this issue?
