Old 20th May 2004, 03:23 AM   (permalink)
Default AC motor wiring diagram for low/high voltage - how to wire??
I have a single phase, 1HP, 60/50Hz motor than I need to wire a pigtail on. The motor can be wired for 115 or 208-230. I am probably going to use it wired for low voltage. I'm not sure how to connect to my three wire (hot/neutral/ground) pigtail.
The wiring diagram for low voltage is:
P1 - UNGR D LINE
P2, T8, T3 - Tape
T2, T5, T4 - Line
How do I connect these to my pigtail???
ALso, if I wanted to switch it over to 220, how would I connect it to a 220 pigtail. The high voltage diagram is:
P1 - UNGR D LINE
P2 - Tape
T8, T3, T2 - Tape
T5, T4 - Line
If possible, maybe a little explaination about the seven wires so I "sort of" know what I am doing.
thanks,
Bill
bill123 is offline
Old 20th May 2004, 06:29 PM   (permalink)
In the low voltage setup attach P1 to neut, T2,T4,T5 to hot and the case to ground ( there should be a male spade lug attached to the case or a green colored screw).
In the Hi setup P1 to hot , T4,T5 to the other hot, ground to the case ( green lug )
All the middle wires that say tape use a wire nut to join the indicated wires together.
This is a best guess, You can lookup the wiring diagram on the net of give a discription here. (I.E Dayton modle bla bla 1 hp 1750rpm 110-220)
TillEulenspiegel is offline
Old 20th May 2004, 09:10 PM   (permalink)
Thanks for the reply. I did not want to make any assumptions and wire it wrong. Your answer is much appreciated!!!!
Bill
bill123 is offline
