| I'm sure it's trivial but I'd like to find COMMON resistor values that with a simple switch or jumper would select between 3.3V or 5V on an LM317 ![]() I don't wish to use a pot like above, but a simple jumper and two resistors. | |
| The more expensive LM117 uses a 240 ohm resistor for R1. The LM317 is supposed to use a 120 om resistor or less so that its output voltage doesn't rise without a load if it has its max rated operating current and if its input voltage is high. With 120 ohms for R1 and 360 ohms for R2 the output is 5.0V. with 120 ohms for R1 and 200 ohms for R2 the output voltage is 3.333V. These resistors are common 5% values.
| Check out Sparkfun..they've got a breadboard PSU with a switch for 3.3v and 5v. I've implemented one on a simple AVR prototboard, that just uses a 2-pin header for a jumper. Pretty accurate. But it used 4 resistors as the jumper 'shorted' a resistor in parallel with another. 240 ohms between out and adjust (two 120's in series) with a 390 and 330 in series from adjust to GND. The jumper just shorts the 330 ohms. probably an over complicated way of doing it, but I built it without designing it first, just a 15 minute job with the parts I had. Roughly 4.97V and 3.29V. Blueteeth
__________________ Inconsistency is the key to flexibility! | |
| R1=120 R2=360 R3=470 A spst will do.
__________________ Superman returns.. | |
| How to get 3.3v to 12v for a project?? | hittinswitches98 | Electronic Projects Design/Ideas/Reviews | 6 | 1st December 2007 08:44 AM |
| LM337 subtitute to LM317??? | AMalonzo | Electronic Projects Design/Ideas/Reviews | 8 | 14th October 2007 02:16 PM |
| 5V and 3.3V with Changing Source | R_C | General Electronics Chat | 15 | 2nd September 2007 07:56 PM |
| Another ICD2 3.3v target question? | Mike, K8LH | Micro Controllers | 2 | 27th August 2007 05:01 PM |
| Converting 5V sinusoidal to 3.3V sinusoidal wave | twinkleBell | General Electronics Chat | 9 | 31st January 2004 12:42 AM |
