Am I wrong in approaching this as a tachometer?
My circuit/electronics skills are pretty limited to following schematics and building a circuit directly from them.
I'm trying to find a circuit to get me 99 percent of the way toward interfacing the following two items for indicating ml/min water flow...
http://img.diytrade.com/cdimg/163371...low_sensor.jpg
15 LED Circular & Linear Bargraphs - LEDtronics - 12991
I'd like the bargraph to register 0 - 2000 ml/min. With straight up (middle) bar indicating 1000ml/min
I realize that this is essentially an LED bargraph tachometer reading pulses from a hall effect switch.
Since RPM measurement with hall switches is such a common task, I'm hoping that there exists
some schematic involving the following ICs to accomplish this with little additional conditioning
or (hopefully no) programing.
LM2917 freq/volt converter IC
LM3914/15/16/17 LED driver ICs
Would the following page be of use to me?
LM2917N, LM3914, Tachometer, PCB
Thanks so much.
Brad
Look thru these, one is for 2917/3914
http://www.electro-tech-online.com/s...earchid=481998
"Nigels Asm tutorials:" www.winpicprog.co.uk/
"Ian Rogers 'C' conversion of Nigels Asm tutorials:" http://www.electro-tech-online.com/c...torials-c.html
Hi Eric
Maybe it is me but the Link no workie, workie?
Ron
hi Ron,
Just retried it OK,??
This is the actual thread for the 2917/3914
I Searched the Forum for 2917 tachometer
Many Thanks
Eric
Lm2917-Lm3914 tachometer schematic
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| schematic for 5 LED chaser circuit using 555 chip | radiant777 | Electronic Projects Design/Ideas/Reviews | 23 | 27th May 2012, 01:25 PM |
| Lm2917-Lm3914 tachometer schematic | caslor | Electronic Projects Design/Ideas/Reviews | 25 | 8th July 2011, 07:53 PM |
| Help with a LED flasher circuit. Schematic inside. | oneslowz28 | Electronic Projects Design/Ideas/Reviews | 15 | 23rd January 2009, 05:26 PM |
| Question regarding this PIC16F628 tachometer schematic… | mbu | Microcontrollers | 32 | 23rd March 2007, 02:41 PM |
| LED tachometer | zachtheterrible | Microcontrollers | 0 | 1st August 2006, 04:24 AM |
