LDO replacement for 7805?
1234 Last »
  1. #1
    Krumlink Krumlink is offline
    I am looking for a replacement for the crappy 7805. For my Binary clock, I am using the 780-05 (the 1.5amp), and it craps out when the voltage reaches about 7volts and I require a extremely smooth voltage because I am using the LS series. It can power my cheapo leds. I am looking for a pin compatable (same pinout) and hookup as the 7805, that has a input voltage at least 6volts. So it will start to fail me at 6 volt input. I am using rechargeable batteries, so that can be pesky. THANKS!
    7805!!!!!!!!!!!!!!!! WOOT SN7400!!!!!!!!!!!!!!!!!!!!!!!!!
    (just some randomness there)
  2. Thread Starter #2
    I also would rather it be TI part. I love Texas instruments, they are nice to me. All their chips are good.
    I need about 750ma or more. I also need 5 volt. THANKS
    0
  3. Thread Starter #3
    I was searchin around and Found a few. This one in particular. I ordered one of each one that I was interested in (3 of them) and ordered only one of them. Here is the link to the one I liked the best:
    http://www.electro-tech-online.com/c...9/tl750m05.pdf
    0
  4. #4
    kchriste kchriste is offline
    LM2937 from National will give 500ma at 5V.
    The LM2940-50IKCSE3 from Ti will give 1A at 5V
    Both are low drop out devices and are pin compatible with the 7805
    0
  5. #5
    audioguru audioguru is offline
    Many low dropout regulators must have a 10uF to 100uF capacitor on their output to ground or they oscillate badly.
    Some oscillate if the capacitor has a low ESR and others oscillate if the capacitor has a high ESR.
    0
  6. Thread Starter #6
    I stuck lots of caps on it to smooth out the voltage since I was dealing with the LS series.
    0
  7. Thread Starter #7
    I got my samples today (one of each, 3 total) and I am going to test them out.
    0
  8. Thread Starter #8
    I replaced the 7805 with the new and improved 780M05 Low Dropout regulator. I got it to put out a decent 5v output (4.98 if you want to get technical) when the voltage hit its roof, of about 6.5 volts. ME HAPPY. The binary clock will run much longer with it on there. about how many mA does a average (any/most) TTL LS series chip use? around 20 ma?
    I am using 21 LEDS at 8ma
    8*21=168ma
    10ttl chips*n(ma use)=x
    0
  9. #9
    TTL LS uses a lot of current. You should have used Cmos because it uses almost no current.
    An LED display also uses a lot of current. An LCD uses a very low current but it needs to be lighted when it is dark.
    0
  10. #10
    whiz115 whiz115 is offline
    sorry for the offtopic but why does TI gives freely all these stuff to everyone that states that studies electronics or works for a company?!
    is it really better advertasing for them?! the transportation costs must be
    huge.. with FedEX and UPS...
    0
1234 Last »
Replacement of HV Diode sujit_51 Datasheets, Manuals or Parts 4 22nd December 2009, 11:51 PM
Desktop Replacement Laptop Marks256 Members Lounge 26 18th July 2007, 10:45 PM
Help Needed - Replacement for BSH102 devonsc Datasheets, Manuals or Parts 1 28th November 2004, 04:18 AM
Replacement Part?? tml1220 Electronic Projects Design/Ideas/Reviews 2 23rd May 2004, 10:01 AM
also need replacement for BS170 and BD679 transistors crysrose Datasheets, Manuals or Parts 3 2nd September 2003, 08:05 PM
Page Time: 0.10111 seconds      Memory: 7,652 KB      Queries: 16      Templates: 0
