    Dismiss Notice
LDO replacement for 7805?
Discussion in 'Datasheets, Manuals or Parts' started by Krumlink, Sep 5, 2007.
  1. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    I am looking for a replacement for the crappy 7805. For my Binary clock, I am using the 780-05 (the 1.5amp), and it craps out when the voltage reaches about 7volts and I require a extremely smooth voltage because I am using the LS series. It can power my cheapo leds. I am looking for a pin compatable (same pinout) and hookup as the 7805, that has a input voltage at least 6volts. So it will start to fail me at 6 volt input. I am using rechargeable batteries, so that can be pesky. THANKS!
    7805!!!!!!!!!!!!!!!! WOOT SN7400!!!!!!!!!!!!!!!!!!!!!!!!!
    (just some randomness there)
  2. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    I also would rather it be TI part. I love Texas instruments, they are nice to me. All their chips are good.
    I need about 750ma or more. I also need 5 volt. THANKS
  3. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. kchriste
    kchriste New Member Forum Supporter
    Jul 23, 2006
    3,677
    47
    Victoria BC, Canada
    LM2937 from National will give 500ma at 5V.
    The LM2940-50IKCSE3 from Ti will give 1A at 5V
    Both are low drop out devices and are pin compatible with the 7805
  6. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,445
    937
    Canada, of course!
    Many low dropout regulators must have a 10uF to 100uF capacitor on their output to ground or they oscillate badly.
    Some oscillate if the capacitor has a low ESR and others oscillate if the capacitor has a high ESR.
  7. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    I stuck lots of caps on it to smooth out the voltage since I was dealing with the LS series.
  8. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    I got my samples today (one of each, 3 total) and I am going to test them out.
  9. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    I replaced the 7805 with the new and improved 780M05 Low Dropout regulator. I got it to put out a decent 5v output (4.98 if you want to get technical) when the voltage hit its roof, of about 6.5 volts. ME HAPPY. The binary clock will run much longer with it on there. about how many mA does a average (any/most) TTL LS series chip use? around 20 ma?
    I am using 21 LEDS at 8ma
    8*21=168ma
    10ttl chips*n(ma use)=x
  10. audioguru
    Mar 16, 2004
    32,445
    937
    Canada, of course!
    TTL LS uses a lot of current. You should have used Cmos because it uses almost no current.
    An LED display also uses a lot of current. An LCD uses a very low current but it needs to be lighted when it is dark.
  11. whiz115
    whiz115 Member
    Jan 29, 2007
    742
    2
    DotGR
    sorry for the offtopic but why does TI gives freely all these stuff to everyone that states that studies electronics or works for a company?! :rolleyes:
    is it really better advertasing for them?! the transportation costs must be
    huge.. with FedEX and UPS...
  12. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    I do study electronics! Im a student in highschool, and they order free samples all the time! I only ordered 1 of 3. Please refrain from making this thread another flame war.
    Audioguru, do you think that 750ma is enough for 10 TTL chips and 22 LEDs at 8ma?
    I couldnt find compliants for the LS series chips that I was using, but if so, How do I pull more ma out?
  13. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    Besides a Switching Regulator? What about in parallel or whatever. I forgot how it goes.
  14. audioguru
    Mar 16, 2004
    32,445
    937
    Canada, of course!
    10 LS-TTL chips at maybe 30mA each plus 22 LEDs at only 8 mA each is a total of 476mA. A regulator in a TO-220 case and without a heatsink will be very hot at 2W.
  15. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    It is a D2PAK with a max output of 750ma. If I put them in parallel dont they disapate the heat through them?
  16. whiz115
    whiz115 Member
    Jan 29, 2007
    742
    2
    DotGR
    it was just a question my friend...i'm not offending or doubting anybody. :)
  17. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    That's alright, he's just a bit sensitive because he's already been involved in a flame war about free samples.
  18. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    Exactly, and it was 6 pages long...
    Now back on topic!!!!!!!!!!!!! (Or I will be mad :mad:)
    So do Parallel Regulators Disapate the heat formed by sharing it through them?
    If so, my D2PAKs (2 of them) will be sharing the 2W of heat by giving 1W of heat through one, and 1W of heat through the other right?
  19. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    ONLINE
    Probably not (at least not well), one will hog most of the current, get red hot and shut down, the second will then get red hot and shut down as well. Could be an interesting low speed oscillator design?.
  20. Krumlink
    Krumlink New Member
    Aug 10, 2007
    2,080
    20
    Michigan, USA
    So what should I do to get the heats out of it?
  21. audioguru
    Mar 16, 2004
    32,445
    937
    Canada, of course!
    You add a heatsink to a regulator to cool it.
Share This Page
