Z80 Hex To Decimal
Starting with 16 by 16 divide:
What you need is an integer divide routine that returns the quotient and the remainder. The most significant digit is obtained by dividing the original number by 10,000 This digit will be the first of five digits in the result. Divide the remainder by 1000. The quotient will be the forth digit of the reult. Divide the remainder by 100. The quotient will be the third digit of the result. Divide the remainder by 10. The quotient will be the forth digit of the result and the remainder will be the fifth digit of the result. You cannot get more than five digits from a 16 bit quantity.
Now your problem a 32 by 32 bit divide
Same idea except now the progression of descending powers of ten starts with a larger value.
hi fm,
Do you want to unpack 4 hex digits into 8 BCD ?
Are the hex digits already 'packed' BCD, as high and low nibbles?
hi fm,
Reply your PM.
I have searched my old Z80 library subr's and books and I cannot find one that I could say is fast, in fact they are slow division subr's.
Also I did a web search, without success in finding a fast subr.
If you do locate a suitable subr, let me know, I would like to have it in my Z80 library.
Regards
