would anyone like to neaten my code please?
bigal_scorpio
Active Member
Hi to all,
I am not yet very good with Microprocessors and am trying to learn MikroBasic. But being a late starter I am finding it difficult to get my head round.
I have written a program to give 3 pulses when the ignition of the car is turned on, then it must wait until the ignition is turned off and again send 3 pulses.
I have managed to get a working program but a friend looked at it and said it could be done much easier and smaller, but seemed unwilling or unable to explain how, so could anyone who uses basic have a quick look and advise me what I SHOULD be doing.
Thanks........Al
'Program to send 3 pulses on ignition being turned on
'then waiting for ignition off to send another set of 3 pulses
' using 12F629 with MCLR off, BODEN off, PWRTE on, WDT off, INT OSC No Clockout
'Power to GPIO.0 from ignition through voltage divider
program tripleflash3
dim t as byte
main:
     TRISIO = %00000001
     CMCON = 7
    if Button(GPIO,0,1,0) then
    goto main
    end if
    if Button(GPIO,0,1,1) then
      For t = 1 to 3
      GPIO.1 = 1
      Delay_ms(100)
      GPIO.1 = 0
      Delay_ms(100)
      next t
    end if
waiter:
    goto waiter
   end if
         For t = 1 to 3
      GPIO.1 = 1
      Delay_ms(100)
      GPIO.1 = 0
      Delay_ms(100)
      next t
      goto main
end.
Don't use MikroBasic, but using an interrupt on change might look nicer. But being in an auto or motorcycle circuit could make it vulnerable to noise. Try a nice fat RC filter like 1k/10uf on GPIO input. So using some generic ideas, try and implement however you do in MikroBasic:
IOC5 = 1  ;Set interrupt on change for GPIO.0
On Interrupt GPIOChange Call Ignition  ;Call sub when GPIO.0 changes
count = 0
Main:
If count = 1 Then call FlashLed
goto Main
Sub Ignition
     count = 1  ;Or boolean True
end sub
Sub FlashLed
     count = 0  ;reset interrupt to False
     ...            ;blinky stuff
end sub
This is how I would tidy your code,
dim t as byte
main:
    TRISIO = %00000001
    CMCON = 7
    while TRUE
        while Button(GPIO,0,1,0)
        wend
            For t = 1 to 3
                GPIO.1 = 1
                Delay_ms(100)
                GPIO.1 = 0
                Delay_ms(100)
            next t
        end if
        while Button(GPIO,0,1,1)
        wend
        For t = 1 to 3
            GPIO.1 = 1
            Delay_ms(100)
            GPIO.1 = 0
            Delay_ms(100)
        next t
    wend
end.
All I have done is remove any gotos and replaced them with while..wend and indented to show where while..wend, for...next and if...endif start and end.
You could try somethink like this:
Dim t As Byte
    TRISIO = %00000001
    CMCON = 7
    Do While 1
        Do While Button(GPIO, 0, 1, 0)      ' wait for some state...
        Loop
        If Button(GPIO, 0, 1, 1) Then
           TripleFlash()
            Do While Button(GPIO, 0, 1, 1)      ' wait for some state...
            Loop
        End If
        TripleFlash()
    Loop
sub procedure TripleFlash()
    Dim t As Byte
    For t = 1 To 3
        GPIO 0.1 = 1
        Delay_ms (100)
        GPIO 0.1 = 0
        Delay_ms (100)
    Next t
End Sub
end.
I don't program in MikroBasic, so the above may need some tweaking to compile.
You'll notice that
* a subroutine is used to replace duplicated code,
* the busy loops e.g.
label:
   if something then goto label
are replaced with
do while something : Loop
* no more gotos - potentially more readable, and you'll be less likely to write spaghetti code
