sahu
A light dimmer works by essentially chopping parts out of the AC voltage.
original code is here ..
broken link removed
#define tx GPIO.GP5
unsigned TMR1 absolute 0x0E;
char current_dim = 0;
char done_flag = 0;
char Command_code, Device_code;
//preload timer1 value 100%, 90%, 80%, 70% 60%, 50%, 40%, 30% 20% and 10%
unsigned preload_time[10] = {65535,63823,63082,62481,61925,61370,60814,\
60259,59656,58916};
//*** interrupt-on-change when zero-crossing occur, preload timer1 value
//*** turn on timer1 to perform delay before gate trigger
if(INTCON.GPIF)
tx = 1;
TMR1 = preload_time[current_dim];//preload_time into Timer1
T1CON.TMR1ON = 1; //start timer1
INTCON.GPIF = 0;
//*** perform gate trigger, turn off itself
if(PIR1.TMR1IF)
T1CON.TMR1ON = 0; //stop timer1
tx = 0; //turn on triac
delay_us(150);
tx = 1; //turn off triac
PIR1.TMR1IF = 0; //clear interrupt flag
if(done_flag == 0)
if(got_data)
Command_code = input_data & 0x7F;
Device_code = input_data >> 7;
if(Device_code == 1)
switch (Command_code)
case 0x12: if(current_dim > 0) current_dim --;
break;
case 0x13: if(current_dim < 9) current_dim ++;
break;
done_flag = 1;
broken link removed
