What's on your "to order" list?
BobW
Active Member
I assume that others do the same as me. I keep a list of parts that I'm running low on (but have no immediate need for) so that I can pad my next parts order and make the shipping costs worthwhile.
I need to order some parts this week, and looking at my list of non-critical order items, there's almost nothing on it. So, I'm looking for inspiration. What should I add to my order to make it worthwhile? (FYI, it will probably be from either Digikey or Mouser).
10 kΩ resistors and 0.1 μF ceramic capacitors. There's no such thing as "too many," you can always use more.
EDIT: Seriously, the answer to your question depends entirely on what sorts of things you like to build or experiment with. What's your "thing"?
Mine are a bit unusual:
  • CM300DY-24H IGBT half-bridge modules
  • 6 inch x 8 foot aluminum dryer duct
  • White paint
  • 8 lb spool of green enamel #26 copper wire (couple of miles worth)
  • 0.75 inch x 100 foot copper or aluminum strip
  • 50 feet of #4 copper wire
  • Copper, brass, or aluminum cable lugs
  • 50x 2uF 1000VDC Aerovox IGBT snubber capacitors
  • Sandpaper
  • 240VAC power connectors/cables
The list goes on....
Hmm, these are on required for project in development list, tho whenever I can, I acquire the basics first 1k, 4.7k, 6.8k, 10k, 15k, 18k, 20k, 22k, 27k, 33k, 34k, 38k, 47k, 56k, so on, then start to eventually add in odd ball variants where I can find them and when needed that are most encountered by what's being built most or likely. 31.2k high side as example combined with an 10K low side to produce 1.235V ref for 5V out from an Linear N-FET regulator IC.
  1. 2x EEU-HD1H221B capacitor replacement for an Cheng cap
  2. 2x EEU-HD1V101 capacitor replacement for a Cheng cap
  3. PYB15-Q48-S12-U CUI DC/DC Converter
  4. 10x NTD2955-1G P-Channel MOSFET
  5. 50x MBA02040C4700FCT00 470R 1% 0.4W
  6. 50x MBA02040C2001FCT00 2K 1% 0.4W
  7. 100x MBA02040C6801FCT00 6.8K 1% 0.4W
  8. 50x MBA02040C2003FCT00 200K 1% 0.4W
  9. 10x EEU-FR1H221B capacitor
  10. 10x EEU-FM1H681L capacitor
  11. 10x TNPW040231K2BEED 31.2K 0.1% 1/16W
  12. 10x TNPW040210K0BEED 10K 0.1% 1/16W
  13. 250x ZOR-12-B-52-0R Jumper 1/16W
  14. 10 CRA2512-FZ-R050ELF 0.05R 1% 3W
  15. 250x JW60ZT0R00 Jumper 3Amp
  16. 10x RXEF010-2 Reset Fuse
  17. some SMD adapters
  18. Headers for the adapters
  19. 10x SB330-E3/54 Schottky Diode
  20. 10x BAT46-TR Schottky Diode
  21. List keeps on going.........
Interesting items. Thanks.
I stocked up on resistors and capacitors on my last couple of orders, but I guess I'll have to check my inventory and see if there are any gaps in the values. I could probably use some more high value film caps (higher than 1 µF). They seem to be coming in handy these days.
In the end, I didn't have any trouble fattening up the order to qualify for free shipping. In fact, it ended up being nearly double what I needed.
I ordered a bunch of plastic project boxes, pushbuttons and panel mount LEDs; things that I'm always running out of. Also added some zero ohm resistors/jumpers as suggested by GromTag (much more professional looking than bare wire jumpers).
Would have ordered 10k resistors and 0.1 µF caps, but I do that on nearly every order, and I now have several lifetime supplies of each.
And then, after the order arrived, I realized that there were few more things that I should have ordered too. :arghh:
Happens all the time to me. Not one order goes by where I don't wish I had added something else to it before submitting.
I believe Mouser has a 15 minute delay between when the order is received and it's pulled because so many people want to add items the minute an order is sent.
I think everybody has this problem!
Add these to your list I just found them at digikey
  • SDURF3060CTR_DiodePair_Com-An_Ultrafast_30a 600v_Replaces_FEP16JTA_U16C40A_.pdf
As per the datasheet you could implement antiparallel diode. That means you need two pairs.
Impressive specs, but I don't need anything that can handle 30A at the moment. Might be of interest to DerStrom8 though, considering what else is on his list.
I'm currently using a 100A 600V 3-phase rectifier in my setup :p
to order list
I want to get several outdoor, tilt & pan & zoom, network cameras. (IR night time light included)
" If wishes were fishes ..... "
What I really need is more time to play with the parts I have."
