what might be wrong
t.man
I have this program for blinking LED...but that's not what happens. LED is always ON. is the delay too small?
whats the problem?
.include "m8def.inc"
	rjmp	RESET		;reset handle
;* Long delay
;* Register variables
	.def  T1      = r1
	.def  T2      = r2
	.def  temp    = r19
;* Code
longDelay:
	clr   T1		;T1 used as delay 2nd count
	clr   T2		;T2 used as delay 3d count
delay_1:
	dec   T2
	brne  delay_1
	dec   T1
	brne  delay_1
	dec   temp
	brne  delay_1
	ret
;* Resets the data direction register D
;* Defines
	.equ  led   = 6		;LED at PD6
;* Code
RESET:
	sbi   DDRD, led		;connect LED to PORTD pin 6
;* Main program
;* This part will let the LED go on and off by w
	.equ  w   =  10 	;enter delaytime w
flash:
	sbi   PORTD, led	;LED on
	ldi   temp, w		;w sec delay
	rcall longDelay
	cbi   PORTD, led	;LED off
	rcall longDelay
	rjmp  flash		;another run
the program is running on mega8 using a 6.144MHz crystal.
whats the problem?
You'll need to add the code to initialize the STACK Pointer or else the stack pointer initialise to all zero after reset. See the following code:
;* Code
RESET:
[color=red][b]        ldi   temp,HIGH(RAMEND)    ; get high byte of end of memory address
        out   SPH,temp
        ldi   temp,LOW(RAMEND)     ; get low byte of end of memory address
        out   SPL,temp
[/b][/color]
;* Main program
