Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
Im trying to find out which makes a/ ac voltage detecto work, capacitors, voltage amlifier, magnitude sensor, or op amp? Im trying to help with a youngsters science project
Voltage could be very simple. If you ever places your hand on a scope probe, you would see your body pick up a huge 60 cycle signal.
So, I would image that a high Z amp connected to an antenna (piece of wire). You might need a 10 M to ground. The output of the OP amp could drive an LED. This is an electric field. I would image that there might be some frequency selection applied to the output.
Current is an Electro Magnetic Field. Not sure how this might work. It may work on (Google hall effect current sensor") principle or it may use a small transformer or ferrite antenna.
The simplest AC detector has a probe connected to an op-amp, and the output is connected to a headphone jack. If the probe comes near AC, the electro-magnetic field given off by the AC conductor induces current in the probe. The op-amp amplifies this current and is translated to sound in the headphones. That is the simplest form I have heard of/made/used. I actually built one on my breadboard once to find where wires were in my wall, so that I could drill a few holes for a cable. It worked really well. Should work fine for a science project.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
