What kinds of caps
Electronman
Hi Folks,
I want to design an active high pass filter to pass signals above 40kHz. It has to have a very high sharpness
What kinds of caps are suitable to do so?
Tantalum I believe would be a decent choice.
Tantalum would actually be bad; they exhibit very high distortion when used in signal applications.
For signal applications, polypropylene film (excellent), mylar (very good) and NP0/C0G ceramics (very good) are what you want to use. Tantalum bad, high-K ceramics also bad (X7R, X5R, Y5V, Z5U, etc). Aluminum electrolytics are OK for DC blocking, but make sure they are a larger value than what the application actually calls for.
The high sharpness means you will need to use a high-order filter or a specialty type filter like an elliptical or chebychev.
How do they exhibit high distortion when used in signal applications? I see them used frequently in audio frequency apps, what's the distortion you're talking about?
Tantalums may be ok for coupling in AC applications but they are a poor choice for deterimining filter characteristics since they typcially have a wide tolerance and are polarized. Speakerguy79's capacitor suggestions are good.
It you don't yet have a filter design you might try Filterpro from TI Active Filter Design Application - FILTERPRO - TI Software Folder.
