I'm seeing pictures in Google and it's not the tool I'm refering to.A gear?
Not exactly. I know this tool is used in Whimshurst machines to obtain 2 discs rotating in opposite directions.Bevel gear?
I think it's. That tool has a name or simply I've to use some gears in a specific configuration?Epicyclic, or sometimes called Planetary, gears configured in a star arrangement? Both the input and output shafts are in the same plane, but rotate in the opposite direction to each other![]()
I've an axle where there is a rotating disc. I know there is a piece that you can attach to that disc and that piece will rotate in opposite direction. Imagine the disc rotates CW, so the piece will rotate CCW.
Do you know the name of that piece?
