what is oshonsoft?
magnatro
:) kinda silly but need some text!
If you load the HEX file using the Oshonsoft menus, the program will run
one file which compile with CSC C & get susecsfuly hex file .load the HEX file using the Oshonsoft menu.Oshonsoft show as PNG file..
CSC C compiler show as..
>>> Warning 203 "main.c" Line 76(1,1): Condition always TRUE
Memory usage: ROM=53% RAM=17% - 30%
0 Errors, 1 Warnings.
why its only running 5 instructions in Oshon Soft.
It will run only the first 5 instructions, the next instruction is CALL 0x3FF, which normally is the internal oscillator calibration value.
As this CALL doesn't get a RETURN in Oshonsoft, the program simulation will terminate.
I would suggest in the binary hex file you change at address 0x0004 the Opcode 0x23FF to 0x0000 [ which will remove that CALL]
Note: Oshonsoft is not able to use the SLEEP instruction.
Shame. Is that true of the licenced software or just the trial version? That 'feature' rules it out for many battery-powered projects. Perhaps that could be mentioned in your Sticky, Eric? :(
hi alec,
Extract from OSH doc 'pichelptopics.txt'
<topic>Special notes
- Watchdog Timer is not simulated (CLRWDT instruction is executed as NOP)
- Power-down Mode is not simulated (SLEEP instruction will stop the simulation)
Ah, understood. I thought we were talking about compiled code, not simulation.
