What if increasing voltage from 12vdc to 36 on a turn signal relay.
Exactly My dear Wattson.
Try one of these on-line 555 calculators:
Some starting values for you:
R1 = 2.2K (Enter as 2200)
R2 = 100K (Enter as 100000)
C1 = 10uF (Enter as 10)
You knew I couldn't do it myself. Just what I needed.
Thanks.
kv :D
Reducing duty cycle on 555 Astable.
This will not affect my circuit I'm building. However, now I have questions concerning limitations with Astable 555.
I was using different values on the 555 calculator and couldn't get it below 50% Duty Cycle.
Does this mean going below 50% can only be program to do so ?
kv
You have to add a diode to get below 50% (see datasheet) or you could connect the load from pin 3 to +V.
1n4148 or something else ?
1n4148 was used a lot on some of the circuit boards we built that required pulse width modulation.
Thanks hero999
kv
Darlington Circuit used on relay's.
A Darlington Circuit with a relay. Posted in another thread seemed to me to be an example of what your talking about when your controlling the Duty Cycle.
Would that be accurate ? Correct me if I'm wrong.
kv
