What clock frequency for a certain baud rate?
atferrari
Most Helpful Member
PIC 18F family EUSART
Many years ago I was able to grasp this but I forgot all about it.
For a certain baud rate, how could I know the EUSART's frequency of the clock when transmitting in Synchronized mode?
I understand that I should define if it is 8 or 9 bits/symbol, right? And add if there is parity bit?
Something like Tx clok freq = Baud rate * (8+1)??
If I look at lost on this, yes, I am.
Please, I know the formulas in the datasheet. What I am asking is the relationship between baud rate and Tx clock frequency because I intend use it in non standard way.
Gracias.
I'm not sure of your specific case but to the best of my knowledge for proper synchronous serial communication, the usarts clock rate needs to be 4 times the synchronized baud rate minimum. Please read carefully as I stated that the usarts clock rate, the usart is fed from the clock frequency by an addition prescaler unit.
You'd have to define non-standard and exactly what you're doing to clarify things further.
Discarded the idea
Gracias for replying Sceadwian.
I was exploring the possibility to use the EUSART Tx clock of a 18F PIC micro to control a switched capacitor filter.
I discarded the idea because to have it running continuously I should keep the micro busy in feeding byte after byte to the EUSART to transmit permanently.
You could always use two chips =)
