Voltage on transformers query
Might seem a simplistic question, but am confused about how you check what the primary voltage on a transformer is when there are no markings at all to identify the values. I don't want to test it with say 240 volts from the mains if its only 120 volts, in case I damage the transformer. I know there is a formula via the windings, but too complicated for me! Advice would be appreciated. Thanks
Thanks Nigel, I have a varian so thats good. The transformer is out of an old 16mm projector, from the 50s, quite a small thing, possibly from an amplifier . Don't know whether its 120 or 240 though, as I said. no markings on it whatsoever.
MaxHeadRoom78
Most Helpful Member
Do you know the voltage rating for the secondary?
If so, feed the secondary with its rated voltage and measure the primary.
Otherwise, feed it with 120v and see of the secondary is realistic for the application.
Was it for the lamp?
Diver300
Most Helpful Member
Put a 240V incandescent light in series with it and connect it to 240 V mains, with no load. If there's only about 120 V across the transformer, then it's probably saturating under those conditions and it's a 120 V transformer. If there's over 200 V across the transformer, it's likely to be a 240 V transformer.
Reloadron
Most Helpful Member
I wouldn't rule out an audio transformer possibility.
Ron
