Volt meter
hi all
im now in process on making volt meter ( not really accurate )
using PIC16F74 ,16x LEDs ,16x 180R resistor and 4 Mhz resonator
lets see
im still waiting to my package come
i will post the video/picture on how it working :)
using this circuit
heres the result
8 leds on and 8 leds off
no comment ? :(
hi TT,
The BAR mode for the LIT led's will consume a lot of power, why not use a DOT led mode.??
The lower LIT 7 leds are redundant
hi TT,
i still dont have bar led on that time
youtube uploader are really slow
i will give you the video link later :)
next task : interface with GP2D12 distance sensor
Here are the results. The two meters give close values at lower voltages. The difference is big while measuring higher end voltages. My guess is
1. Resistors value changed because of getting heated at high voltage; that changes the input voltage,
2. Approximation errors are larger in magnitudes (not in %) at higher end of measurements.
hi
what is the worst thing can happen if its past 20V ? :D
