Veroboard?
PDubya
Am I just totally not seeing it - is there any place to get Veroboard? I see perfboard everywhere. Any suggestions?
If your location was filled in, perhaps we could make suggestions?.
You could try looking for 'stripboard', Veroboard is a specific manufacturers trademark (probably the original manufacturer?).
Ah, sorry :(.
Stripboard eh? That seemed to be the ticket! I wasn't finding anybody selling it under the veroboard name. While I've got you captive Nigel ;)... what would the pushbuttons on the PIC tutorial "Switch Board" be called? I looked on mouser for about 20 minutes and didn't find anything - but there were over 6k different parts under "pushbutton" (and I wasn't going through them all!).
Thanks again!
PDubya said:
Ah, sorry :(.
They are called "push buttons taken out of old TV sets" :D
Just look in any old electronics gear you have, you find these sorts of switches everywhere. All you need is a simple push to make switch, you could always alter the layout to make any fit - it's not at all critical.
Ah, I see ;).
I don't think I have anything I could rip apart - but I'll have to keep my eyes peeled!
Thanks!!!
PDubya,
On the switches, you probably could order a switches grab bag from Jameco. P/N 18235 @ $8.95. The Schwab's School Selection contains 9 grab bags including switches, LEDs, capacitors, diodes, transistors, etc for $39.95. P/N 163213. The only problem that I had when ordering the Schwab's grab bag was that 50% of the transistors had no markings. Here is a link to the catalog page: **broken link removed**
Grab bags are usually pretty scary... though the prices don't seem too bad at all. I'd just really like to get some pushbuttons that would work on a breadboard easilly. The type he had in his project looked perfect ;). I just had no idea where to even begin to narrow the list down on mouser.
Heh... I agree, although the LEDs, and switches grab bags I came out ok on. The switch that I use most often on breadboard:
Jameco has @ $0.74 EA starting with a minimum of 4. I originally got them from a vellman kit.
Yeah, I use that kind on my breadboard. Tactile switch is the keyword, and I generally find that's summed up by "it clicks when you press it" :)
I bought a lot to make a simple keyboard for my synth, but they have nearly all worn out with only very light use, I can't actually figure out why. My spare ones are ok.
Not much to figure out, they are only rated for fairly light use, I suspect using them for a keyboard is abusing them! :D
Try Ebay,
I got some from the USA about 1 year ago.
Years ago I was using strong blue epoxy-fiberglass Veroboard, then all that was available was cheap and brittle phenolic, so I have been buying an excellent Chinese epoxy-fiberglass copy.
