vb6 and barcode
silent_thunder
i have here already a barcode reader..
then i also have vb6 program connected to ms access2003..i tried to store info to database though vb6 and i made it...
my question is this, how can i use the barcode reader to search the information stored in ms access database?
Open a database,
    Set MyDB = OpenDatabase("c:\my documents\test.mdb")
Then use it,
Sub updateSoldTo(offset As Integer)
    SQL$ = "SELECT DISTINCTROW Car.MAKE, Car.MODEL, Car.YEAR, " _
    & "Car.StockNo, Car.DispatchDate, soldto.SoldCustID, " _
    & "Car.SoldPrice, Car.SoldDate " _
    & "FROM Car INNER JOIN soldto ON Car.StockNo = soldto.SoldStockNo " _
    & "Where ((soldto.soldCustID) = " & Format$(MyCustID, "###0") & ")" _
    & "ORDER BY Car.DispatchDate DESC;"
    Set MyRST = MyDB.OpenRecordset(SQL$)
    If MyRST.RecordCount <> 0 Then
        With MyRST
            SMake.Text = !make
            Smodel.Text = !model
            SYear.Text = !Year
            SStockNo.Text = !StockNo
            SSoldDate.Text = Format(!SoldDate, "dd mmm yy")
            If IsDate(!dispatchdate) Then
                SDispatchDate.Text = !dispatchdate
            Else
                SDispatchDate.Text = ""
            End If
            SPrice.Text = "£" & !soldPrice
        End With
    Else
        SMake.Text = ""
        Smodel.Text = ""
        SYear.Text = ""
        SStockNo.Text = ""
        SPrice.Text = ""
        SSoldDate.Text = ""
    End If
    MyRST.Close
End Sub
The above is copied straight from a VB6 project from many years ago and is probably badly written but it should get you started.
..thnks for the efort....at last i made it..hehehe
..no need for coding in the VB for barcode..hehe
just put the search code in the text box..then it will do the job..
