VA's on a transformer?
gregmcc
I'm busy with a project which I need to power on 5 relays at the same time.
The relay's are 5V each and consume 150mA when powered.
So in total they should draw 750mA
I bought a transformer but now am not sure its 'powerful' enough?
Its a 230V/12V - 3VA 50Hz transformer.
Does that mean it can put out 3V at 1A (ie 5V at 3/5A?)
Would that mean is too small to drive all my relays on at the same time? I would need a 750mA * 5V (3.75VA) Transformer?
I would have to put the output of the transformer through a rectifier and then a 5V regulator - would that make things even worse?
What would happen if the transformer is too small to power all the relay - would they just not all power on, or would the relay eventually burn out?
Yes, but as it's a 12V transformer it's maximum current will only be 3/12A
Yes - if you're using a higher voltage transformer, then you should use higher voltage relays and feed them from before the regulator - but 3VA 1s still too small a transformer.
It would burn out the transformer, and almost certainly the device wouldn't work properly before that happened.
Nigel - thanks for the explanation. Guess its back to the electronics shop tomorrow.
So a 0-12V 1A transformer should do the trick?
Your transformer won't do. You need a 10VA transformer. But why not get a 5/6 volt wall-wart that puts out the right current and is allready DC out! E
Thats a good idea - didnt think of that :)
I have one right next to me I"m not using - a Nokia 5V 2A charger. :)
No. It means it can put out 12V at up to ~250mA (1/4A). So the tranny is unsuitable and would burn out. You need a lower voltage higher current transformer, e.g. 9V with at least 9VA rating. Bear in mind that the rectified peak voltage is 1.4 times the rated RMS voltage of a transformer, the rectifier drops ~1.4V if it's a bridge type, the rectifier output needs a high value smoothing capacitor, the regulator input voltage needs to be a few volts (depending on regulator type) above its 5V output, and at 750mA the regulator will create a lot of heat so will need a heatsink.
LOL ;)
Sounds like a trap.
1. According to the stuff I know, your little Transformer will not cut it. It will run very hot while it lasts ;)
2. As per the last question.....the Relays will not burn out eventually as they have never really worked anyway....
Strange questions deserve strange answers.
tvtech
