ADWSystems
I'm not sure this is the best topic for this question, but probably the best place to start.
I'm looking to read the current draw of a 220VAC single phase motor via a microprocessor (probably arduino).
I found this CT https://www.sparkfun.com/products/11005
which links to this page https://openenergymonitor.org/emon/node/58
which in turn has a link to this page https://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface that has a nice drawing at the bottom of the first screen, as well as some (I think) useful instructions for selecting the resistor values.
Now for the questions: It appears the output of the CT/input to the controller is an oscillating waveform (pin labeled 'Arduino Input'). Won't the oscillation effect the readings by the A/D converter in the controller?
If I was to smooth the waveform, is it just a matter of adding a full-wave rectifier and capacitor? The AC inputs would be the points listed as 'mid-point' and 'Arduino Input'. The new controller input would be the rectifier + terminal, and the rectifier - Terminal connected to the common ground.
